Question about Nintendo Wii Console
Console fell and now front cover is broken and apart
The front cover tabs are broken and won't stay on unit, the red wire is broken in two, a little plug is off and 1 tiny board is loose in there. Can you buy a replacement front cover complete with electronics? We live in Ontario Canada if there is a place that sells such things.
  • rowntree Dec 29, 2008
    actually the little boards are only to light up the disc slot so we took them out and taped on the cover as the tabs were broken and the wii works just fine.
  • daddy-th Feb 13, 2009
    i have a disc that my 2 year old broken off in side my wii console. Can it be fixed
    Problem Solver:
  • 12 Answers
No you cant fix it you have toget a new one
Posted on Dec 28, 2008
1995 7.3 idi wont fire fuel or eather
have you taken off the valve covers to see if the connectors are broken the wires to the injectors and the glow plugs and they are molded into the valve cover gasket over time the little tab that holds them together breaks and they come apart the gaskets are about 110 dollars through dorman
Feb 12, 2014 | 1995 Ford F350
Xbox fell while open now it won't close
its off track,,try pulling out ,,pushing left and right,,if still dont get it,,other option is to take it apart to fix,,good luck
Dec 27, 2012 | Microsoft Xbox 360 Console
How do u open my ps3 console
There is a Black sticky label on the hard drive end of the unit..Pull it off Get a #8 torx bit driver and remove the screw under where the label was........Pull the top cover about 1/2 " towards other end of unit.
Remove all the philips screws that have arrows near them.
The top cover folds away from the rear of the unit. Be careful not to break any tabs on the front of the case. There are also small wires attached to the top cover assby.
Jul 03, 2011 | Sony Playstation 3 (PS3) Console
The Easy Mount button recessed itself into the unit. Took unit apart but see why this happened but the part doesn't stay fixed when reassembled. Also two tiny washers fell out when I opened up the unit and...
I just had this same problem. It's an easy fix. The "washers" that fell out aren't washers, they're the reason that the button fell into the unit. They are plastic "rivet heads" from the way the frame of the button is melted onto the cover. You can throw them away. I used super glue to re-attach the button to the cover.
Sep 17, 2010 | Passport 8500 Radar Detector
Embedded light sensor stays red all the time
The back cover is called the a micro/dust assembly. See #21 here:
http://www.ereplacementparts.com/hoover-u6630900-windtunnel-selfpropelled-bagless-vacuum-parts-c-37315_37337_37584.html
The little sensor should be in the round recess in the top of that assembly. When you are putting the cover back on you have to use a pair of needle nose pliers to push the sensor into the round recess until it is snug. It is hard to do because the wires to the sensor are very short and you have to be careful not to break the wires on the sensor. The sensor is a little microphone that senses the noise of the dirt going through the EDF. The first time I did mine I didn't push it in hard enough and came out of the EDF recess and fell inside the vacuum body.
Jun 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have si 637 quadra. cleaning the unit both little thin plates at the end of filter fell off. the unit works. how important is repair this ?
If you're talking about those little plastic tabs at the bottom, they aren't important. Their job is to wipe the ionizing wires when you take the grid out or replace it.
Jan 15, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
Disk will not read
Chances are the tab from the top of the door of your console has broken off. It is a very simple problem to fix. It is either the one at the front just behind the power/reset button or the one at the back just behind the little tab that holds your disc in place and stops it from spinning while your door is open. Open up your console... there are three small holes at the front... two are at the very front and one is on the right side and a bit smaller that is one of the ones that may be missing a tab. Look at the underside of the door... is there a tab directly above that hole if so then it is not that one, if it is not there, simply glue it back on or use something small and about have the size of the two tabs at the front to synthesize it. If it is there look at the back behind the thing that stops your disc from spinning and see if the tab on the top is missing from there and if it is do the same for if it was missing from the front only make it twice as long as the tabs in front. Hope this helped
Jul 30, 2008 | Sony PlayStation 2 (PS2) Console
How to open Iomega 650 USB CDRW
Remove the front cover.
Use thin screwdriver to pry side-locking tabs tward the center of drive.
Tabs are on both sides, near the front.
Also on both sides near the back, thru small access holes at the back, on the sides.
Comes right apart, no broken bits.
Feb 02, 2008 | Iomega Ext.DVD Id +/- Rw USB2.0 HD Burner
JVC KD-S70R
you have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Oct 25, 2006 | JVC KD-S580 CD Player
Nintendo Wii Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
