Question about Blanco Essence Kitchen Faucet with Side Spray ....
Blanco side sprayer fell off the hose
How do I get it back on? I do not see any nuts or bolts or threads. Help.
    Scholar:
  • 68 Answers
If the sprayer fell off the hose and you see no threads to screw it back on with, then the retainer clip has gone bad. Unscrew the sprayer at the bottom of the piece that came off the hose. There should be a little metal clip. That clip holds the sprayer on the hose. If the clip came off once it will again. Buy a new sprayer assembly with a new clip, unless someone has one sitting around.
Please rate this response and good luck, Phil
Posted on Dec 28, 2008
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
Faucet insert replacement
Contact Blanco to find out why the insert they sent doesn't fit.
Oct 28, 2017 | Blanco 157-090-CR Rados Kitchen Faucet...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Difficulty in turning a single handle faucet from side to side. Under the sink there is a barrel shaped weight that has come off and appears to have been wrapped around one of the hoses. Your...
The reason it is hard to turn from side to side is the top nut located under the lever is too tight and the the weight does go around the flex line that leads to the faucet but is only the to pull the sprayer back in place.
Aug 23, 2010 | Blanco Classic Single Handle Faucet with...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
How do I replace the side spray base for my Blanco 086-ST Sprayer?
Hello. The side spray base is held in place with a washer and a nut on the underside of the sink. Sometimes this nut gets a bit corroded and can be difficult to remove. Here is what you will need to do. Borrow or purchase a faucet wrench. These are available at all hardware stores, home depot, lowes. Also get a can of a lubricating spray called WD 40. This is sometimes a two person job so call a friend. One person under the sink and one above, use the faucet wrench to grab ahold of the nut surrounding the hose. As you are looking up at it it will come off by turning it counter clockwise. If it doesn't come right off spray it with WD-40 and leave it for 30 minutes while the penetrating oil does it's magic.
You will also have to unscrew the sprayer and pull off the little metal keeper that will keep the hose from sliding through the opening.
Once these things are done you will have removed the old base and you will be ready to replace it by reversing the steps. Regards, Joe
PS kindly rate my answer. thank you.
Jan 26, 2010 | Blanco Essence Kitchen Faucet with Side...
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
Oct 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Blanco Faucet Side Sprayer
It may be a result of extreme temperature changes from the time you tightened the shank until the time it broke however this is very unlikely.Typically the shank only needs to be tightened until it is stationary and immovable by normal operating stresses which is a very low torque value. As a general rule of thumb I use finger tight and an additional quarter turn. I once used epoxy and a short nipple to resolve the same issue but I had the advantage of having a pipe threading machine to fabricate the perfect size nipple and used a large washer and coupling to finish it off. If you try a new shank try tightening it as little as possible and I believe this will resolve the issue. Thanks for using Fix Ya and I hope this is of assistance to you.
Nov 08, 2008 | Blanco Plumbing
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Blanco Essence Kitchen Faucet with Side Spray .... Logo
192 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
