Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Moen positemp cartridge won't come out of brass body housing
I've pulled ,tried to rotate, squirted silicone lubricant It doesn't move . I first removed the retainer clip
    Scholar:
  • 68 Answers
If the clip has been removed it will come out. these things get incredibly tough to remove. Moen does sell a little puller just for these. I have used a socket with the screw in the stem to act as a puller.
If you have the water off AND your sure your have the correct new cartridge you can give the valve a little heat to help soften things up a touch. Use a heat gun with caution
Please rate this response and good luck, Phil
Posted on Dec 28, 2008
    Problem Solver:
  • 4 Answers
I used ViceGrips on the shaft, and stuck a straightblade screwdriver between the ViceGrips and the brass shell. A little prying, and it popped out.
Posted on Feb 07, 2009
Moen ca87553
You need a #1225 replacement cartridge. Pop the cap off of the handle. Use phillips screwdriver to remove the handle screw. Pull the handle off. Next, unscrew the two screws holding the cover plate on. After removing plate, there should be two integral stops, one on each side of the valve. Close the valves using a straight slot screwdriver. Pull on the brass cartridge spindle to ensure that the water is off. Remove the stop tube, which is a chrome cylinder at the center of the valve body. Look for a brass retainer clip at the top of the cylindrical portion of the valve body where the handle connects. It has a small hole and after you pull it out, you will see that it horse shoe shaped. Use your pliers or an awl stuck through the hole to pull the clip out. Note the position of your cartridge. There is a notch on the end of one side of the brass spindle at the center of the cartridge. Make note of its position. If you install it and get hot and cold reversed, just take the handle back off, and spin the brass spindle 180 degrees. The replacement cartridge comes with a white plastic tool designed to make removal easier. Use it. After loosening with the plastic tool, take your pliers and grab the brass stem. Pull as straight as you can. If cartridge will not budge, you might need a Moen cartridge removal tool. Do not spray with WD-40 or Liquid Wrench unless you like that taste in your water. If your clip won't go back on, it's because you didn't align the two ears on the cartridge. The ears should be at three o'clock and six o'clock. The cartridge must also be pushed in all the way. Good luck!
Dec 08, 2013 | Moen 3175 Legend One Handle Shower Faucet...
Removing Moen Cartridge with BROKEN shaft
Alan, I'm a certified plumber for over 30 years specializing in service. I hate telling you this but what you have is a Moen posi-temp and there is no tricks or easy way to remove it other than a cartridge puller which won't help in your case since it's already broken. Just break out your drill and carefully have at it, BUT don't leave the water on it won't help and may be dangerous and/or ruin your drill. For some reason on all Moens cartridges the rubber grommet tend to adhere themselves to the brass valve body's. Sorry, wish I had better news...
Jun 05, 2013 | Moen & Replacement Cartridge
How do you remove a cartiarigde from moen shower body (single handle)
There is a special tool that yo can use to remove an old and stuck moen cartridge and they can found at your hardware store. Now before you remove the cartridge be sure to remove a small brass or copper pin located at the top of the stem. you will see a groove in the stem cover where the pin is located. once the pin is removed hookup the puller and remove stem. sometime you are able just to grab the stem with a pair of pliers and give a good pull and twist to get it out. don't pull to hard to damage the plumbing in the wall. good luck and I hope I was able to help. As always, TURN OFF THE WATER FIRST...
Feb 11, 2011 | Moen & One Handle Tub & Shower Faucet
How can i get my faucets and shower to last longer then a month or two handels ar hard to pull won't shout off i tried both brass and plastic
You can try lubrication, usually silicone based. Some designs certainly do bind up faster than others. I prefer American Standard for just this reason. Hard to throw away a lifetime warranty faucet, but if you have to service it all of the time, eventually you need a new one.
Dec 13, 2010 | Moen Home
How do you remove the old cartridge pn# 1222 after you have removed the temp. limit stop kit?
If you are referring to a Posi Temp cartridge they can be tough to remove from the valve body but there is a specific Moen 'puller' tool available. Basicially, once the 'U' shaped brass clip, which holds the cartridge on place is removed, the old cartridge (including the brass stem) will pull out completely. However they are frequently stuck in place and require some force to break free. A small plastic tool is included with the new cartridge - it isn't worth much, IMO but at least try it. Slide it over the stem so that it fits snuggly against the old cartridge and twist it with channel locks or crescent wrench. You may be successful in getting the cartridge to turn, one it does it will usually then pull out. Grasp the brass stem with vise grips/channel locks and pull the cartridge straight out. If it doesn't budge, you will likely need the specific tool mentioned above which screws into the stem (where the screw for the handle would normally fit) and is tightened down against the valve body. The pressure applied is similar to an auto. brake puller, pulling the valve out. Be careful in exerting any pressure against the valve body because it may not be adequately fastened to blocking inside the wall cavity and too much or excessive pulling may cause damage to the water supply lines.
Make sure before the install the new cartridge the valve body is clean and free of any build up. I usually take a little emery cloth and clean it out then flush the valve with water. Also use plenty of additional silicon/plumbers grease on all the black rubber seals before inserting it . Make sure it is not upside down and fits into the valve body all the way. The brass retaining clip is then re-inserted. Be careful not to lose it as a replacement is not included with the new valve and may not be easy to come by. Good luck!
Oct 25, 2010 | Moen & Replacement Cartridge
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
On my Moen shower facet
There is a small "U" type clip that comes down in front area to hold it in, I assume that has been removed. The new cartridge should have come with a small tool (usually plastic) that you put over the cartridge, push it in, and turn the body of the cartridge, and it should start to ride up on higher brass sleeve and start to pull itself out. If you look at vertical part of cartridge, it is sitting back in on low spot of the sleeve. That tool, or a pair of strong needle nose pliers,needs to be against the sides of the vertical part of the cartridge, in such a way that when you rotate the cartridge, it rides up on higher part of sleeve, and pulls itself outward.
Apr 16, 2010 | Moen & One Handle Tub & Shower Faucet
No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Feb 01, 2010 | Moen 2352 Chrome Chateau Single Handle...
I cant stop my Moen single lever kitchen faucet from leaking. how can I fix it?
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Sep 08, 2009 | Moen 87530 Touch Control Single Handle...
Replace new moen 1200 stem, still leaks due to scratches housing
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Jan 07, 2009 | Moen & Replacement Cartridge
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
866 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
