Question about Acer AL1717 17" LCD Monitor
Black lines in Acer AL1717
I turned my monitor on and black lines goes across the screen. I can still see the pictures etc, but very annoying lines. Is it shot?
  • dsmalt Jan 10, 2009
    Had to take it in to the shop and it had a 3 year warranty (I didn't know it had) so its being fixed. thanks for your input though.
    Problem Solver:
  • 6 Answers
On the power supply PCB are two 25V 220uf capacitors that will be leading. Replace them and the picture should be back to normal.
Posted on Oct 28, 2009
Check the singel cabels
Posted on Jan 10, 2009
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
I turn it on and it comes on screen goes black and it comes on again and goes black again
You should try it on another PC first to make sure it is not the PC video card problem.
Common problem with LCD monitors is due to bad DC filter caps in the power supply section as you can see here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
There are more than one version of the AL1717 as you can see in my ACER album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 24, 2011 | Acer AL1717 17" LCD Monitor
My AL1717 monitor shows a flickering power signal (blinks off & on) but shows black screen and nothing else. Thank You
Most likely a problem with internal capacitors either blown or swelling or leaking. Can be repaired by replacing the faulty capacitors but recommended that this be carried out be a qualifed technician
Dec 30, 2010 | Acer AL1717 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
Need to turn off internal audio on flat screen to use headset
When you plug in a headset or mic into the bottom or the side of the monitor, this should automaticly disable the internal speakers on the monitor.
May 26, 2009 | Acer AL1717 17" LCD Monitor
Fix my monitor
as saferi1 have stated you can try your cpu with another monitor so as to be sure.The problem is similar to the one i saw on the horizontal out put check that area.
Sep 18, 2008 | Acer AL1717 17" LCD Monitor
Monitor
i also have this problem. it may be fault of VGA card in LCD.
Aug 27, 2008 | Acer AL1717 17" LCD Monitor
Acer Monitor AL1917 W
Yes.
When you unplug the data cable from the PC, you should usually get a 'no signal' message from the screen itself.
Other LCDs (like in this case), you have to plug it in and turn it one slightly before your PC goes on, so it can auto-adjust to the resolution your PC has.
Jan 26, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
354 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
