Question about Maytag Neptune MDE5500AY Electric Dryer
Baffles are loose on my dyer maytag neptune mde5500
I am trying to dismantle front without breaking anything , how do i go about this ? is this thw way to access dryer baffles to tighten them
  • Anonymous Dec 30, 2008
    i dont know how to put videos on my Youtube accout(channel )
  • 145 Answers
Hi Nick, welcome to FixYa!
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into.
Next, remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru) Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
next, look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Now you can lift up the top of the machine, and rotate the drum so that the loose baffle is at the top so you can work on the baffle easily. Rotate the drum to the next baffle, etc.
I hope you find this answer helpful.
Posted on Dec 28, 2008
Baffle is loose in dryer,how do I tighten it
Gain access from the top. tighten up baffle with 1/4 nutdriver i believe.
Feb 07, 2011 | Dryers
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
1 of 3 fins on inside is loose & hanging by 1 screw.
Access to the bottom of the baffles for tightening the screws requires the lifting of the top cover which also requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Rotate the drum until the baffle screws are positioned on the top for tightening.
May 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Jan 22, 2010 | Maytag Dryers
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
322 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
