Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Beeps repeatedly, lense won't retract...won't take pictures?
Camera not working....was fine one minute and the next the lense won't retract, it beeps upon powering up, and it will go to review picture mode and show the pictures on the camera, but won't take any new pics, and the lense won't retract? When you power off it beeps repeatedly?
  • Anonymous Apr 03, 2009
    One morning I turned my camera on and was reviewing my pictures. I then tried to turn the camera off and the lens did not retract. I turned it back on and realized the camera would not take photos or videos. When I shift it into camera mode it beeps several times and either shuts off on its own or returns to photo review mode. Then lens has still not retracted since then. I have tried charging the battery but it has not made a difference.
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Posted on Dec 30, 2008
I had all the same problems with the camera that first started with a "memory card error" (the memory card was not the problem). I also only could get a "background" screen on the LCD. I was totally frustrated to the point that I figured I'd have to buy another camera. So, I figure it wouldn't hurt to manhandle the camera. I lightly tried to pushed the lens back in while pressing the power on-off button... The camera lens pushed and jerked (I didn't really fight the push). Thinking I did nothing... I then tried turning it on again....like magic, the camera turned on normally with screen showing ready to take the next picture. And no more "memory card error" either. I don't really know how this worked, or whether it'll work for anyone else, but it did for me.
Posted on Aug 03, 2009
  • tonytickler Mar 29, 2011
    Wow it actually worked. I took it apart which is not the easiest thing to master when u cant see screws the size of termites. i probably could have just pushed the lens in with some force without opening the case, but it eventually started opening and closing alittle more each time until it was operating fully.
Beeps about 3 times and turns off. lense wont retract
Your problem may be due to a weak/worn out battery or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your battery may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 02, 2009 | Olympus Stylus 1010 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Our Camera was dropped and the lense was out while it was dropped. The lense now appears to be bent in a downward direction and wont retract in or out. The camera did a series of beeps and turned off. Now...
I had a similar problem with my FE 280. I just used a pair of plyers and gently straighten the lens and it works fine. You are going to pay to fix it more than the camera is worth so no harm in trying
Nov 01, 2009 | Olympus FE-360 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Lens stays open
The lens would have to be repaired or replaced. You'd be looking at a $95-$125 repair
Dec 27, 2008 | Cameras
Camera beeps five times, doesn't work
the beeps mean the lens can't be opened or closed. maybe something stuck or it's just failed?
Aug 30, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Olympus Camedia C5050 Zoom
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
Aug 19, 2007 | Olympus Camedia C-350 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
511 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
