Question about Dell 922 All-In-One InkJet Printer
Dell Photo All-in-One Printer 944 cartridge carrier malfunction
The color cartridge carrier lid will not snap shut when loaded with a new cartridge. I do have the correct cartridge and have replaced it before, but now it will not close tightly and the printer will not print. Who should I go to to see about this? Thank you. -Cindy
944 cartridge missing. Faulty cartridge. try a couple of the old cartridges that were low on ink and the printer should work
Posted on Oct 12, 2009
    Genius:
  • 2,120 Answers
Nobody fixes ink-jet printers anymore.
If the old cart will go back in OK, it could be a bad cartridge.
Posted on Dec 28, 2008
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
  • Jun 05, 2011 | Office Equipment & Supplies
    Dell 944 instruction to install new ink cartridge
    CAUTION: Before performing any of the procedures listed in this section, read and
    follow the safety information in "CAUTION: SAFETY INSTRUCTIONS" on page 9.
    Dell ink cartridges are only available through Dell. You can order more ink online at
    www.dell.com/supplies or by phone. To order by phone, see "Ordering Supplies" on page 2.
    Dell recommends Dell ink cartridges for your printer. Dell does not provide warranty coverage
    for problems caused by using accessories, parts, or components not supplied by Dell.
    1 Turn on your printer.
    2 Lift the printer unit, and position the scanner support between the tabs to hold it open.
    3 Press down on the ink cartridge lever to raise each ink cartridge lid.
    4 Remove the old ink cartridges.
    5 Store the cartridges in an air-tight container, such as the storage unit you received with
    6 If you are installing new ink cartridges, remove the sticker and transparent tape from the
    7 Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the
    carrier.
    8 Snap each lid closed.
    9 Lift the printer unit, and hold the scanner support up while lowering the printer unit until
    See page 71, section 7 in the user guide:
    http://support.dell.com/support/edocs/systems/944/en/om/om_en.pdf
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 01, 2011 | Dell Photo 964 All-In-One InkJet Printer
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
    How do I install the printer cartrige? I do not have the booklet...
    2. Open the front cover.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    How do I change the ink cartriges in my printer
    1.Turn on your printer.
    2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
    3.Press down on the ink cartridge lever to raise each ink cartridge lid.
    4.Remove the old ink cartridges.
    5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
    6.Snap each lid closed.
    7.Lower the scanner base unit until it is completely closed.
    Enjoy printing...
    Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
    my ink cartridge lid wont close after replacing ink and i have clicked down the cartidge.
    Jan 26, 2010 | Dell 922 All-In-One InkJet Printer
    Show me how to install new ink cartridge onv305
    hi eileenoreill,
    you can try these steps:
    2. Lift the scanner base unit.
    3. Press down on the ink cartridge lever to raise each ink cartridge lid.
    4. Remove the old ink cartridge.
    5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
    6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
    7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    8. Snap each lid closed.
    9. Lower the scanner base unit until it is completely closed
    10. Snap each lid closed.
    just update me if the issue is not yet resolved.
    Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
    Dell 922 All-In-One InkJet Printer Logo
    323 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
