Dvd recorder message (This picture cannot be recorded)
Recorded ok until cable box replaced on12/23/08 due to power failure. New box has HDMI connection. Old was component video. TV is Sony KDL-40V2500. Cable box is Atlanta Scientific 4250 HD. The message stated in summary happens on every station, every program and every show I tried to record. Both analog and digital.
''Sony brushed me off with this: I'm sorry for the difficulty you're experiencing to record programs on your Sony DVD Recorder. Copyright-protection errors may occur when attempting to record programs that are copyright protected or when recording from a digital network recorder. Typically, pay movie services, pay-per-view and on-demand programs are broadcast with copyright protection. This copyright protection cannot be overridden and is normal operation.''
Must be some other answer. Time Warner does not block everything. Please Help........John Allen
  • jerryguerrer May 11, 2010
    I have the same problem. My cable box is Scientific Atlanta and my dvd recorder is Sony. I get the same (This picture cannot be recorded). The cable box has an option "COPY TO VCR". I tried using this but I had no luck. How about you? If you go to recorded list menu select the program you are trying to record and it has an option to Copy to VCR. I tried it with no success. Can you try it and see what happens.
Palmbeach
  • 185 Answers
SOURCE: copyrighted dvds
Copyright protection is to prevent you from illegally stealing material and breaking the law.
If you Google for DVD copying software you will find lots of programs out there. Do remember though, copying DVDs and Video is illegal!
Posted on Mar 24, 2008
Merkader
  • 21 Answers
SOURCE: VCR copyright
On the side that faces out of the tape that sticks out of the vcr there should be a square indent. This makes the tape read only and tells the player that it is copyrighted. If you were to cover it with a piece of tape it should work. Just make sure the tape is on really good so that it doesn't fall off into your machine. I'm assuming they are your personal family videos that you accidentally broke the tab off of and not actual hollywood videos that you would get into trouble for copying.
Posted on May 01, 2008
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
josetapia162
  • 155 Answers
SOURCE: will not record copyright programs
No, now they code protec the new systems so we can't infringe in the copyrights. Try to find a old one & tranfer your movies to DvD.
Posted on Jun 29, 2010
gregs_rockin
  • 274 Answers
SOURCE: Hi. We have an old analog TV (Sony) which has a new digibox running through it (since the switch over). Was fine, but over the last few weeks, intermittently, the screen goes black with EXT 1 in the t
Your picture tube is on the (Verge) Of going.
Posted on Oct 09, 2012
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
WHERE IS THE AUDIO OUTPUT WHEN USING COMPONENT CABLES ON A YAMAHA RX-V571 RECEIVER
How are you hooking up the receiver to the dvd recorder? Component connections are only going to carry video. For audio, you would have to connect the cd-r output rca jacks to the recorder audio inputs.
Jan 08, 2013 | Yamaha RX-V571 Home theater receiver with...
Hi, I have a Samsung HR720 DVD-TV recorder and since we have gone digital the quality of the picture recorded is blurry. I have checked the back of the recorder and it doesn't appear to be any option...
Hi, Check the settings in the TV menu. Set the sharpness abit higher. Also if you have already you need a set top box (PVR) to view digital signal and to record it as well. Good luck.
Jul 21, 2011 | Samsung DVD-HR720 DVD Recorder
May 06, 2009 | Televison & Video
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
Televison & Video Logo
848 people viewed this question
Top Televison & Video Experts
