Question about JBL SCS145.5 System
Want to use logiteh z-5500 didgital subwoofer For A/V
I have 2 logitech subs.And no other parts. it only as wired speaker outputs
and i want to use both subs for my Yamaha A/V receiver.That as two sub outputs.(RCA jacks) So how do I use these two PCsub woofers on my A/V reciver?
5 Suggested Answers
SOURCE: jbl PB12 powered sub woofer
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Posted on Jan 05, 2008
SOURCE: psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Posted on Feb 10, 2009
SOURCE: Hi, I have 2 JBL
i had to buy a complete amp and replace the old
Posted on Oct 07, 2010
idrvnsx2
  • 60 Answers
SOURCE: Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Posted on Oct 23, 2011
How to i install a Pioneer DEH-1250 to a Jensen 5500?I got these as a gift and its like confusing me.Please help me out and send me a diagram on the input wiring from the Pioneer player to the Jensen 5500-...
Hi, what you want to do is just connect the speaker wires from the head unit straight across to the pre-amp inputs of the amp. If you have a sub, also connect the pre-amp outputs of the head unit to the 2 sub inputs of the amp. Connect the blue wire of the head unit to the turn-on terminal of the amp and connect power wires to both units. May I ask what speakers are you using?
Aug 14, 2011 | Jensen Car Audio & Video
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
How do i wire up my mtx 15 5500 sub woofer dual voice coil any one know i have tried several ways
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm. Wiring Option #2
1_2ohmdvc_1ohm.gif Wiring Option #2
this is for dual 4 ohm coils
1_4ohmdvc_2ohm.gif Wiring Option #2
Mar 06, 2010 | MTX Thunder 5500 T5510-04 Car Subwoofer
Looking for a subwoofer for logitechZ-5500
Hi, As Logitech does not sell this spare part, I suggest you to check on website such as ebay. Thanks and have a nice day !
J -
Mar 04, 2010 | Logitech Z-5500 Computer Speakers
I'm the proud owner of the Logitech Z 5500 speaker. I noticed that I wasn't getting any lows from the sub so I ran the 'TEST' button on the remote only to realize their was no output from the sub - all...
Got the same problem, dont think its the fuze, have a feeling its one of those pins when you take the big wire out. Thikig of taking it apart right now, will let u know if i figure it out
Jul 10, 2009 | Logitech Z-5500 Computer Speakers
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
Logitech Z 5500
Dennis
First things first:
1) you can buy on audio stores, boxes for 10 inch speakers
then you can do this kind of work,
I try to do what you did, and you know what happend! *&^%$
Open Sky
Feb 10, 2008 | Logitech Z-5500 Computer Speakers
Logitch Z-5500
ok what sound card do you have on your system maybe your sound card is not working grate
Jan 20, 2008 | Logitech Z-5500 Computer Speakers
JBL SCS145.5 System Logo
261 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
