Question about Dell XPS™ 600 PC Desktop
A new hard drive
Got a new hdd 250gb sata for xps 600 the pc can't recognized it
The solution for this problem is simple. I experienced it when I changed my HD last year. You need to download a SATA driver form nvidia for your motherboard. Make sure you have it on a floppy drive. Then when reinstalling the OS, on the blue screen at start, up press F6 when prompted. Then when it asks you, load the floppy driver. Problem solved. 100%
Posted on Dec 09, 2009
  • 51 Answers
If you added the hard drive in addition to your current drive, make sure the sata connector on your hard drive is enabled in your BIOS. You should see which function key to press to get into the BIOS when your system is first booting up (might say F2 for setup, or something of that nature). You should find a catagory to enable the different SATA connectors on your motherboard. If that is not the issue, make sure the jumpers on the drive are set up correctly. Here is a link to set the on how to set the jumper.
The PC could possibly be trying to assign a drive letter to the drive that is already in use. Right click on My Computer, select Manage, select disk management, see if your new drive is listed. If it is, you can right click on the drive, then select change drive letter, and change it to a letter that is not already in use.
Let me know if you still needing assistance.
Posted on Dec 28, 2008
    Novelist:
  • 101 Answers
The sata connector was probably disabled in the BIOS to prevent you from getting a missing drive error on startup before this was installed. Press F2 at the Dell Splash screen to enter BIOS setup, come down to Drives and change the setting for the sata connector to ON. When you reboot go back into the BIOS setup and it should report the Drive ID and capacity.
I have a Dell XPS 600 Desktop. I have a new HDD SATA. I installed the new HDD and I try install Windows XP by pressing F12 to boot from disk. It take me to a screen where it says, Press enter to install...
Don't press F12, that tells the Dell to restore Windows from a hidden partition located on the original hard drive. Since you are using a new drive, you need to boot from the Windows XP CD and follow the instruction to load the operating system.
Oct 30, 2010 | Dell XPS 600 PC Desktop
Windows won't recognize the HDD in my Dell XPS 400.
hawkdawg
In regards to installing your new harddrive if you are installed a SATA drive the issue is that not all versions of Windows has SATA drives native on the Windows install CD. So during the first part of the install you will need to press F6 to load the SATA drivers of the driver CD. If you do not have it you can download the drivers from support.dell.com
Let me know if you have any more problems or questions
Issken
Apr 13, 2010 | Dell XPS 400 PC Desktop
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
250Gb hard drive for Acer travelmate 2300
No. I have tried a 250 Gb but my 2303 wont carry it. it will only recognize up to 130Gb but I did not try it with a 120Gb internally, my 250Gb IDE -HDD will run as an external but there is a power surge warning that comes up when I connect it, however I can run a 500 Gb SATA HDD with out this happening. MURRAY the MAGNIFICENT
Apr 08, 2009 | Acer TravelMate 2300 Notebook
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
SumsungHDD Fails to load OS
Try:
Have you got a decent spinup?
Are the rest of the drives working properly, if they are not it may suggest faulty PSU.
Try connecting to a diffrent pc, or purchase a USB sata convertor
Aug 13, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Dell XPS™ 600 PC Desktop Logo
245 people viewed this question
Alun Cox
