Question about Jetway 939GT4-SLI-G Motherboard
Problem with mobo upgrade ... From Intel CPU to AMD CPU
I fixed the problem with AMD mobo powering itself after 10 or so seconds. I had to cut the plastic nubs ( 4 of them ) on the yellow plastic retainer around the CPU. This allows the Thermaltake heatsink/fan assy. to sit lower and make contact with the CPU die. Note to Lolita ... Yes that was the problem ... 1/32" does make a diff...The PC now runs.... My new problem is ... Since this is a mobo upgrade Intel to AMD I followed the Microsoft upgrade proceedure (Article ID 824125) which states with the old system running ... in insert the XP cdrom and let autorun start ... click on Upgrade ... etc ... follow the instructions till the sustem reboots ... powerdown the PC .. swap the mobo ... power on and let the Upgrade to continue ... That all work until the Second reboot ... XP started loading and just when the XP logo goes away ... Blue Screen of Death ... Stop: 0x0000007E (0xC00000005, 0xF775C750, 0xF79F430, 0xF79F712C) Any Ideas? Is this a problem because of was Intel now AMD? Thanks in advance Dale G.
OK, here's what I did in the same case: After installing new motherboard, I booted from Windows XP CD and typed "R" to run the Recovery Console. I went into Windows\System32\Drivers and deleted every file whose name started with "Intel". Then I booted windows normally, it loaded and happily detected the new hardware (including new CPU). If you do not have windows CD, you can try booting in safe mode (it worked for me) and delete the files. But this might make the new hardware detection a bit less "clean", though it should still work OK.
Posted on Jul 18, 2009
    Problem Solver:
  • 5 Answers
Hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Posted on Apr 26, 2007
Gateway laptop stayed on blue screen and it says intalling updates but hasnt moved from 1 of 159
The only thing that you can do at this point is Shut it down. If this is windows 10 it will recover by itself when it powers back on. To shut it down you can hold the power button down for 10 seconds.
Sep 28, 2015 | Gateway NE52204u Silver 15.6" Notebook 1.5...
Msi 870-g45 failing to POST?
hi, i had a similar issue some time ago, dependng on your hardware i would suggest you look into a psu tester, or swap it out for a friend's psu, i assume you've ripped everything apart and put it back together to see if some dust was shorting somewhere, is it related to heat maybe, expansion of cracking can sometimes occur in computers that have gotten hot in the past, especially in the circuitry behind the cpu.
Good luck
Nik
Jun 04, 2012 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
Sounds like you built this puppy.
1) Does it use metal standoff's to hold the motherboard up off the Support Plate? (Standoff is metal, Spacer is plastic)
Do the standoff's match EVERY mounting hole in the motherboard?
To wit, there isn't a standoff sitting on the support plate, that doesn't match up to a mounting hole in the motherboard?
If there is a standoff in the wrong spot, it could be shorting against the exposed solder joints on the bottom of the motherboard.
2) is the 4-pin +12 volt power cable from the Power Supply plugged into the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ Two Yellow 12 Volt wires, two Black Ground wires ]
3) Thermal paste applied, and properly? AMD processors don't play when it comes to heat. If they reach the thermal limit, (Like any Processor), they turn off, BUT, an AMD will turn off in a heartbeat.
Heatsink sitting flat on the top of the Processor's case? I use a 'birds-eye' view with the mobo out, and look across the side. (Sides, ends)
4) Zalman fan doing it's thing? Spinning?
Spinning all the time, no intermediate spinning of spinning a few times, and stop?
Spinning at the proper RPM?
5) Patriot ram seated well? Locks are in tight?
Didn't get bumped when you were hooking up power cables?
Remove/re-seat. Only takes a few minutes, and will help you sleep better tonight.
(Both of those ram memory modules in the same channel?)
6) Power Supply known to be good?
What is with the 40GB Seagate harddrive? Typo, and meant 400GB?
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Needle on the speedomer has goon all of the way around and is pegged up against the pin
I had this same thing occur in my 2001 Town & Country, it always happens when I have to do any electrical work that requires unhooking the battery. Once the van restarts, the needle swings around backwards, but there is a small retaining nub that keeps it from making a full revolution. In my 2001 this is easily fixed, you just pop off the dashplate around the upper half of the steering column, and then there are four bolts holding the clear plastic instrument panel cover in place. Once you remove those, you just pull off the speedometer needle, then replace it on the other side of the retaining nub. Be careful when touching the little nub however, it is rubbery and quite delicate. Hope this works for your 2002!
Apr 19, 2009 | 2002 Chrysler Town & Country
NEW MOBO MSI K9N SLI V2
the short answer is YES you need the additional power to the 4 pin molex.
Post your power supply brand and specs along with the copmplete spec of your PC and I'll be able to give some further advice regarding best option for you
Jul 16, 2008 | Intel Motherboard
Computer Build Problem
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Apr 09, 2008 | Intel Motherboard
Zoom toggle switch problem
you need:
1: a small and strong phillips screwdriver.
2. a small piece of medium strength plastic.
(I used a wall anchor like you would use for drywall)
3. superglue
4: about 15 minutes
5. some gumption
6. a bit of sandpaper, in case you screw up step 4.
step 0: You are about to void any warranty. Accept this, and move on. Take out the battery and the memory card.
step 1: remove case of camera. be careful not to strip or loose your your screws.
step 2: gently give the thing a shake. likely a tiny piece of black plastic will fall out. this is the piece that originally attached to the back of the zoom rocker button. if it doesn't come out, don't worry.
step 3: take a look at the back side of the still functioning side of the rocker button. you will see a tiny nub on the back. this nub compresses the pressure switch that is built into the circuit card of the camera, activating the zoom.
step 4: cut a piece of plastic that is about the right thickness to replace the missing nub on the non-functioning side of the button. you will be better off cutting it a bit too thick than too thin.
step 5a: VERY carefully superglue the bit of plastic to the back of the button. you don't need that much glue.
Setp 5b: let me repeat, YOU DON"T NEED THAT MUCH GLUE!
Step 6: Let the glue dry. completely. I mean it.
step 7: replace the case, and about half the screws. put the battery and card back in.
step 8. power on, and test the zoom. It should work now. if it feels like the button is too loose, or still isn't making contact, you cut the plastic too small; Sand or snip it off and start again.
Step 9. If it feels like the button is too hard to push, the plastic bit is too large. You can cut it down a bit, sand it, or just put the rest of the screws in and be thankfull that you repaired your camera for about 2 cents worth of material, and 15 minutes of work.
Step 10: make sure you don't have any extra parts. make sure you didn't screw up another button while you were mucking about.
I've done this. It works. Repaired mine about 9 months ago, and no issues since...well, I put the button in upside down, but it works exactly the same, so that doesn't count as an issue.
If FUBAR your camera, I'm not responsible.
Long live Nikon,
-aboniks
Sep 19, 2005 | Nikon Coolpix 4500 Digital Camera
Jetway 939GT4-SLI-G Motherboard Logo
320 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
