Question about Akai PT50DL24 Television
Tv keeps turning off
My akai dlp tv model number pt50dl24 keeps tuning off after a few seconds and all lights keep flashing tv was working great last night got up this morning and had this problem I turned the tv on and this is what is hapening now
  • Anonymous Mar 21, 2009
    the exact same thing is happening to me....i think its the buld (lamp) going out...i live in a small town (100,000) and NO ONE in town carries the bulb...according to akai website, the tv doesn't even exist..wow
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: tv shuts off after a few minutes akai pt50dl24
Not sure if this will help I have a infocus 61in dlp I've had a lot of trouble with the fan even if the fan is working the control wire or a should say on my TV when it got hot and the wiring broke down so it would shut off I replaced the wires I'm not sure if he'll have that same option but it is something to look at it seems like the projectors or projection TVs have a fit over heat I wish you the best of luck I must clarify the fan goes to my bulb is a three wire the center wire tells the computer to turn everything on my and outside one's is the fan the fan is one directional and this may be of no help as well but a 9 V battery placed across the outside terminals told me the wires were bad I hope some of this information will help if not I hope you get the help you need for it once again good luck
Posted on Aug 01, 2009
  • 34 Answers
SOURCE: Akai pt50dl24 plays well but the picture is darker
This TV was made by Samsung, and more than likely the CRT's weak. The only way to correct it is to replace the CRT's which is expensive.
Posted on Nov 08, 2009
noobcybort
  • 199 Answers
SOURCE: My Akai PT50DL24 turns off on it's own several
Hello !
Akai the problem is with the Tunner card (video section) some chip either has leakage or is overheating this should be checked the same checking should done on the power supply . by a technician .
good luck
Posted on Dec 08, 2009
SOURCE: akai pt50dl24 keeps turning off on its own
My 63" AKAI TV tuens itself off by itself anytime, no pattern?
Posted on Jun 16, 2010
Tv comes on then turns itself off but the power button is flashing two green lights
It may be a blown capacitor. Take the back cover off and inspect all capacitors on the power supply board to see if any are rounded on top instead of flat. You can find capacitors at most electronic retailers or online. They are relatively easy to replace yourself or have a technician replace it.
Dec 28, 2012 | Akai PT50DL24 50" DLP TV
50 inch dlp, keeps turning off, been happening since set was a year old, but now it won;t stay on at all some people say scrap it instead of repair what should I do
You probably have a bad lamp. They usually last 8,000 hours. If its not the lamp, it is probably a bad power supply or lamp ballast which is about a 200-300 dollar fix.
Jun 07, 2011 | Akai PT50DL24 50" DLP TV
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai pt50dl24 keeps turning off on its own
Apr 12, 2010 | Akai PT50DL24 Television
Keeps cutting off while watching tv
If the set shuts off then tries to turn itself back on then I suspect the lamp. The lamp part number is BP96-01472A. If it just shuts down and then you are able to turn it back on, then in most cases you have a bad digital board. The part number for the main/digital board is BP94-02262D...Please take a few moments to rate my answer. Thanks...
Nov 24, 2009 | Akai PT50DL24 Television
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT50DL24 Television Logo
176 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
