Mustek ScanExpress A3 USB 1200 Pro Scanner Logo
Code 43 for Scan Express A3 USB 1200
Hi There -- My scanner has suddenly stopped working. My OS is Windows 7. The scanner has been working fine up until this point, but now, "The Scanner is not connected, please check the cable." When I unplug and replug in the scanner, I get a pop-up message that reads "One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it," When I click the error message, It takes me to a window listing all of the USB devices connected to the root hub, with the one signifying the scanner in bold. When I double click on it in the list, it reads below: "Windows has stopped this device because it has reported problems (Code 43)." Any suggestions? I have already tried uninstalling and reinstalling all of the drivers, and trying to plug the scanner into all of the other ports, no luck.
2 Related Answers
Anonymous
  • Posted on Mar 02, 2008
SOURCE: mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Anonymous
  • Posted on Dec 15, 2010
SOURCE: Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
2helpful
I need to download a Mustek SE A3 USB 600 PRO Driver for Windows 7 for the device which got lost.
Hi anderoland
There is no support at Mustek's for Windows 7 . You can't use your device under this OS .
best regards ,
fanaudi .
I cant get my new macbook pro to recognize my mustek Scan Express A3 USB 1200 pro, and i haven't been able to find a driver to fix it so far.
Here is the page to download the drivers you need for the Mustek ScanExpress A3 USB 1200 Pro Scanner:
http://www.mustek.com/mustek/supportdrivers.php
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
1helpful
No drivers windows 7 for scanner MUSTEK ScanExpress A3 USB
you can download driver on this page
http://www.mustek.com/mustek/supportdrivers.php?&show=drivers&disp_cat=Scanner&disp_sr=USB%20Port&disp_mod=ScanExpress%20A3%20USB%202400%20Pro&disp_catid=18&disp_srid=31&disp_modid=230
If this helps orsolves the issue, please rate it and give a testimonial for myresponse
1helpful
Driver for mustek phto express
I have a mastak bearpow nagative scaner but i lost software. Thats why this scaner is useless. please give me software.
Mustek Scanner won't initialize
It could be something to do with the bundled software having a missing or corrupt TWAIN32 file.. But you can Scan using Windows XP itself.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Scroll down to the Scanning part, and see if that is of any use to you..
Hope this helps
Chris (ziraffa)
I need a scanner that will scan 10X14 pictures
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Mustek 1200 UB Flat bed scanner
SELAM BENDE MUSTEK 1200 UB VAR XP NASIL çALIŞTIRA BİLİRİM XP DOSYAYI YüKLEDİM AMA çALIŞMIYOR 98 çALIŞIYOR YARDİMCI OLURSANIZ SEVİNİRİM TŞKLER [email protected] teşekkürler
Top Mustek Office Equipment & Supplies Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
