Question about Samsung TX-R3080WH 30" TV
Dropped TV My flat screen tipped over in the bed of my pickup during transport. It fell from the normal upright position onto the screen side. The screen itself was not scratched or damaged. There is a crack on the border of the top. The TV is made by Samsung and is a 30" wide screen tube HDTV. The problem is the picture cuts off on the left hand side of the screen. It is kind of like picture was move to the left by about an inch. Is there a way it can be recalibrated to fit back onto the screen?
  • RaleighRobin May 03, 2008
    When assembling the stand for my Sanyo 32" Flat Screen TV, I inadvertently put the wrong screws into the stand's components. There were two packages of screws, one with three screws and one with four screws, but nothing was included in the instructions as to which screws go where. This resulted in the stand being unstable. Within the first week of owning this tv, it fell over and the screen hit the corner of the table it was sitting on. When I turned the set on, there was an area on the left side of the screen that looked like a jagged streak of lightening and a lot of colored lines running up and down the screen. There is a tiny white spot of light where the point of impact occurred. No damage can be seen when the set is turned off. Is this television destroyed of can it be repaired? Is this something that might be covered by the extended warranty? Where do I take it to have it looked at? So far, I have done nothing but set it on a furniture pad against a wall to protect it from another fall.
    Genius:
  • 1,074 Answers
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
Posted on Apr 26, 2007
Driver's car seat back will not lock in upright position
Mechanism most likely broken . I had a Hyundai and was rear ended and the mechanism broke plus I know of several other seat backs that broke on people
Jun 06, 2016 | 2009 Honda Accord
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
Will I damage the refrigerator by laying on side to transport.
Hi csmgen,
It is advisable to avoid laying a refrigerator on its side. The oil in the compressor can flow into the cooling lines when the refrigerator is tipped onto its side. When returned to an upright position, there is a risk that the oil will not completely drain from the cooling lines and the refrigerator will not cool.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | Maytag MSD2754G Side by Side Refrigerator
Need to transport a Toshiba 43vs9ua 43" TV....can it be laid down on its screen or back for 3 hours??? And if so what is the standing period prior to turning it on?
If this is a tube type TV it should be transported the same way as a Plasma type. Upright. The reason for this is because if the screen is not supported in the centre and evenly across the whole area of the surface, it may break being made of glass and heavy. I normally transport them face toward the side of the van and up against 2" of foam rubber with tie down straps to keep it steady.
There is no standing time before use however, if the climate is different to the transport, (air conditioned and cool but warm in the room it is put in), it is adviseable to let it reach the same temperature avoidind problems with condensation. This normally takes a couple of hours.
Hope that helps.
Mar 29, 2011 | Televison & Video
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
Moving a 40" Sony LCD HDTV Bravia
I would suggest to use foam and bubble wrap to soften the vibration to the TV.
The TV should place in a vertical position.
Good Luck with your cross-country trip.
Jul 29, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I leave Michigan for the entire winter and there is no heat in the house, will below freezing weather hurt my lcd tv. Also can i store the tv in a flat position.
If you mean flat so you can slide it under a bed for example so it's not visible to someone looking through the windows, then that is fine. The easiest way to do it is lay a blanket on the floor, lay the TV onto the blanket on its back and put another blanket over the screen to help keep dust off it, then slide the whole thing under the bed.
The below freezing I cannot comment on, I live in Australia were cold means anything thats not over 30 degreess celcius =)
Apr 11, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Samsung TX-R3080WH 30" TV Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
