Question about Nikon Coolpix L1 Digital Camera
SDHC memory card
Why can not a SDHC card work in my coolpix L1, can i get a update.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The L1 is an old camera, before the SDHC standard. There is no forward compatibility (SD devices can't use SDHC cards), only backward (SDHC devices can use SD cards).
The latest version of the firmware is available at http://support.nikontech.com/app/answers/detail/a_id/13783
That still won't let you use SDHC cards.
Posted on Dec 30, 2009
Not read memory card
The Coolpix L110 can work with SD and SDHC cards up to 32 GB. If you bought a SDXC card, it won't work in your camera. I don't think Nikon will come with an update of the firmware, only for bigger memory cards, because you can shoot hundreds of pictures already on a 32 GB card. Also be sure the Lock switch on the side of the card is in the unlock position. Like the 64GB card on the picture.
Jan 08, 2014 | Nikon Coolpix L110 Digital Camera
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
Why won't my Nikon coolpix L1 camera work with my sandisk SDHC card?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Another possibility- SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Finally, it may be that the card is not formatted. Most come pre-formatted, but there is a format function in the camera that you can try. Formatting deletes anything already on the card.
Dec 01, 2010 | Nikon Coolpix L1 Digital Camera
How about listing the cameras that the SDHC card either will or will not work with. Will my Nikon Coolpix L- 4 a candidate?
The list of cameras that can use SDHC cards would be in the thousands....not very practical. Anyway, unfortunately your camera cannot use them.
Nov 08, 2010 | Nikon Coolpix L1 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
Bought a SanDisk 4GB SDHC card but camera won't accept.Should I have bought an SD memory card instead?
That camera does not support SDHC cards only SD memory cards, take the card back and i expect they will gladly swap it for you.
Regards.
Jul 09, 2009 | Nikon Coolpix 3200 Digital Camera
SDHC memory card compatability with 7600
no, will not take SDHC.
SD only sorry
Regards
Richard.
Jun 30, 2008 | Nikon Coolpix 7600 Digital Camera
Nikon Coolpix L1 Digital Camera Logo
713 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
