Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
My vacuum lost power completely. it will not turn on at all.
I have replaced bag and filter. also have pressed the reset button. still no power
  • jewelbless Apr 12, 2009
    My vac lost all power. I changed the bag and made sure all the hoses were clear. Pressed the reset button and still doesn't work
Have you checked the screw that holds the handle to the vaccuum?
If it is loose, the power will not go on.
Try it!
Worked for me!
Christina
Posted on Jan 13, 2009
I was vacuuming and my vacuum just shut down completely and won't turn back on at all
If your machine has a reset button see if it needs reset. If it does not have a reset button it likely has an internal reset that shuts it off if the motor gets too hot and will reset when the motor cools down. Overheating is usually caused by something restricting the airflow, it could be a clog or the bag is too full or the filters need replaced.
Feb 18, 2017 | Vacuums
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
May 20, 2009 | Riccar 8955 Upright Vacuum
How to reset?
The button I think you are talking about is the bag switch. It is located in the bottom right corner where you put the bag. If the bag does not cover it, the machine will not run.
Also, when the machine cuts off when the bag is full, you have to push the power switch off and back on to reset the full bag switch located in the switch control housing inside the machine.
Mar 13, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
http://dysonmanuals.llc.nu/
Chris..
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
232 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
