Question about Sony Playstation 3 (PS3) Console
Ps3 working fine this mornin
Then ...pluged it back in tonight getting no picture at all both hdmi and normal ps cable ps3 is on and will eject game and reload but still no picture
    Problem Solver:
  • 4 Answers
Try turning on your PS3 but keep holding your finger on the power button see if that helps
Posted on Dec 28, 2008
Ps turns on but no picture or sound on tv i've tried a different cable and its just the same. the tv appears to pick up some sort of connection but not what it should. The ps turns on and all the lights...
I will take a shot at your problem and assume you are using a HDMI cable. First you need to turn the PS3 on by the switch on the PS3. Then press and hold the On/Off button on the PS3, keeping it pressed until you here a clear beep and then a couple of seconds after you should hear a second beep. Once you hear the second beep take your finger off the button. Now as long as you are on the correct HDMI channel the rest should be on the screen for you to complete.
Please Note - If you have it working on a particular TV, then decide to unplug the PS3 and put it on another TV, there is a very good chance it will be blank again. This is normal because each TV has different setting, pixels, size, etc, and the HDMI has to be set to each individual TV. Once you get use to the settings. It takes no more than 1 minute to do.
Cheers, and hopefully this will solve your problem.
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 works with a hdmi cable but it will not display to any tv.
hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
No picture, no sound, standby button doesn't work normally
Make sure all your connections are tight and if you're using hdmi try using component cables.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
PS-3 no sound
What probably happened is a problem with the HDMI cable. It must have a gouge, or an internal slash. If you get a new HDMI cable, it will work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-52631no picture through the HDMI connections
had the same problem get a new cable its not the tv its the ps3 if the cable is tight in the ps3 it works fine or if you set the ps3 just right the cable will fit fine and work
May 24, 2008 | Mitsubishi WD-52631 52" Projection HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Ps3 startup software won't load correctly
turn on ps3 leave on stand by (red light), hold eject button and power button until you hear beeps and a message appears. connect controller and press ps button. system restore screen should appear, select restart system and from there it should restore everything back to normal. This worked for me, for clear instruction go to http://blogallalong.com/2008/12/05/ps3-green-light-on-and-system-wont-start/#comment-31058
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
