Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
GE Profile oven control panel not working
Our oven (15 years old) is not responding to the control panel. The gas range is working fine. The power is on. When we press 'bake', for example, the baking timer displays. We can't get to the baking temp setting. Also, the increase/decrease buttons are unresponsive. It almost seems like the memory of the control panel needs to be cleared. Any ideas? Thanks.
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
SOURCE: Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Posted on Mar 17, 2008
aborcass
  • 2651 Answers
SOURCE: temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Posted on Oct 07, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Posted on Nov 11, 2008
  • 57 Answers
SOURCE: Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Posted on Dec 02, 2008
My gas oven wont light
The ignitor that lights the burner has failed...
Checkout this tip that I wrote...it will help uou understand your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 04, 2010 | GE Profile 30" Self-Cleaning Freestanding...
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Jul 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
go to this web site
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Profile Gas/Electric Oven Range that has stop working
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Nov 21, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
364 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
