Will not dry
Washer will go though wash and drying cycle but it will not get hot. The heating element is ok and working. Is it the timer and where can i get one?
  • 15,935 Answers
It appears your heater element has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Yes I have a whirlpool DU1345XTVB1 dishwasher. Just got in July. After each wash cycle the dishes are not dry. I have been using Finish gelpacs w/jetdry & also have a off brand drying agent in...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Dishwasher heats but when it starts the rinse and dry cycle the heating delay light comes on and won't proceed to the next cycle
Sounds like the heating element is not working. Usually the hot water temp is OK for the wash cycle (110 to 140 degrees) but the rinse cycle asks for 140 to 160 which requires the heating element. (As does the dry cycle).
Oct 21, 2009 | Dishwashers
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
