Question about Ricoh Aficio MP1600SPF Copier
Paper drawer won't open all the way and it won't copy
Above
  • jpd8 May 11, 2010
    What is the make and model of the device? and.. and it won't ...what?
  • 58 Answers
1. Turn the system off
2. Go to the right side of the unit and open the side panel will drop down
3. Move to the front of the machines and pull the drawer out as far as it will go, if it stops that meant there is a piece of paper caught in the take up area.
4. Go back to the side where you opened the panel and look for the lead edge of the paper, if you see it grab hold and up and towards you.
5. If you can't see the lead edge of the paper you will have to force the paper drawer out, just pull hard and the drawer and a piece of paper will come out.
6. Remove the drawer completly and then look in the paper drawer cavity for the remaining piece of paper.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 18, 2009
How do you open the CD drawer?
There is a button on the drawer. It is located near the center toward the bottom. It is often difficult to see. I painted mine white using "white out" error correction liquid. If the drawer is not opening after pushing the button then use a paper clip to aid in the opening. Insert the point of the paper clip into the hole that is next to the drawer eject button as described above.
Oct 19, 2014 | Acer Computers & Internet
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
Jun 02, 2012 | Computers & Internet
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
When I went to run the copy machine this morning it jammed. The paper jammed where it grabs the paper. I removed the drawer and got the paper out. Put the drawer back in the machine and it was fine. I...
This could be a faulty sensor, but as a no cost option it could also be a worn pickup roller.. just try to roughen it with some sandpaper... see if that helps..
Apr 19, 2017 | Canon imageRUNNER 210S Copier
MINOLTA CSPRO EP1083 PHOTOCOPIER NOT WORKING DISPLAYS "COF 30 " AND STOPS COPYING
Open the paper drawer and switch the green button which is located towards the back of the paper drawer on your left. My copier does this everytime I add paper.
Oct 11, 2010 | Minolta EP1083 CS/PRO Copier
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Jan 28, 2009 | Brother HL-4040CN Laser Printer
Paper drawer is stuck open?
there is a piece of paper stuck behind the paper drawer, remove the drawer and then look inside, also open side panel and you may be able to see part of the paper there also .
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Ricoh Aficio MP1600SPF Copier Logo
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
