Question about Durabrand PDV-705 Portable DVD Player
It cant read a dvd "no disc"
When I put a dvd in The system display loading, but after a few seconds says no disc. I tried cleaning the player, and I have had tried using several different discs, so Could you tell me how to fix it?
    Problem Solver:
  • 22 Answers
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
Posted on Dec 29, 2008
Dvd player reads "no disc" when I put disc in
Are the discs copy's or originals if there copy's some systems will not read them, if there originals then clean disc on laser eye with a cleaner disc
Mar 07, 2014 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
The dvd player reads the cds but when dvd is inserted it says no disc after few seconds of load
the laser is weak. need to replace. you could also try opening unit and clean lens with alcohol.
Mar 23, 2011 | Philips HTS3400/37B System
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
Doesn't play cd's or dvd's. Player says its LOADING for a few seconds then it says NO DISC
It's unable to read the source disc.Try using a comerically recorded disc.Try several different ones.Use a disc cleaner to clean the laser if all else fails
Sep 16, 2009 | Philips HTS-3565 Theater System
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
When a disc is loaded, it reads no disc, and disc cannot be played.
It is very possible that the lens motor has burnt out. Sometimes the capacitors on the motherborard short out causing the gear timing to go out..
The only thing you can do to fix this is to take the cover off. Get cotton swab and dip it rubbing alcohol and clean the glass laser eye with it.
Jun 03, 2009 | Samsung DVD-HD850 DVD Player
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Durabrand PDV-705 Portable DVD Player Logo
94 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
