Question about Nintendo Game Boy Advance Console
Problems entering name/signing in
After much persistence the Leapster 2 finally starting working (20 batteries later!). Now it does not allow me to sign in a name. Is anyone else having this problem?
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on Feb 10, 2009
  • 106 Answers
Fiend your solution direct from nintendo. Here is your solution....
Problems entering name/signing in - ffae17a.jpg
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-10
Posted on Jul 23, 2009
Forget the code for enter parent lock i no remember the code for leap frog
Instructions
    • 1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
    • 2 Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
    • 3 Press the reset button with the pointed object. Hold the button down for about three to five seconds.
    • 4 Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
    • 5 Press the Leapster's "on/off" button. When the Leapster comes on, enter the country informationicon1.png and the player's name.
    • 6 Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Read more: http://www.ehow.com/how_8430044_reset-leapfrog-leapster.html#ixzz33FgzCf1j
May 31, 2014 | Toys
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
I can't calibrate the leapster.I can't get pass enter a name
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
If you have questions please let me know.Thanks for using Fixya
Aug 03, 2011 | LeapFrog Leapster 2 Learning System
I turn on my daughter's Leapster 2. I sign in. I click "Cartridge Game". The screen goes black & then It goes back to the "Leapster 2" screen, followed by the "if you...
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Jun 08, 2011 | LeapFrog Leapster 2 Learning System
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
How do you enter a name on the Leapster 2?
I am guessing you have all 3 spots filled and need to delet one. HOLD DOWN in sequence HOME + A + Left Arrow. So you have to hold all 3 buttons and then the X shows up. I was able to then delete the Sign In name I wanted.
Dec 10, 2010 | Leapster Learning System
I can not sign to the leapster i can see the names but can't pick
I have had the same problem and my sons leapster2 has been replaced twice because of it now i am having problems with the SD card. It seems like they have not managed to perfect the faults in this product. Try calibrating it (turn it on while holding down the hint button and then press A and follow the marks with the pen then restart and if that doesn't work I would take it back to where you boought it either that or contact leapfrog direct. Hope that helps.
Jun 10, 2009 | LeapFrog Leapster 2 Learning System
Owners manual
how do I remove the names that were originally put in and add my sons name to the leapster 2
Jan 04, 2009 | Leapster Learning System
How do I delete a name from Leapster? I bought it used.
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
Dec 23, 2008 | LeapFrog LeapSter L-Max Console
Nintendo Game Boy Advance Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Troy Gorman
Troy Gorman
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
