Question about KitchenAid KUDS01DJ - Multiple Color Dishwasher
Dishwasher not getting water
I have a KitchenAid KUDS01DJWH0. It is not spraying any water. We had a repairman in who found that the pump was not getting power, so it appeared that the control board had gone bad. We ordered and installed a new control board but we still get no water. The machine will run through its entire cycle but no water comes in. What should we do next, aside from calling in the repairman again?
  • 38 Answers
Check voltage at fill valve, If you have 110v check to make sure you have water at valve. If you have water, replace valve, if no water check plumbing.
Posted on Mar 10, 2009
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Does not wash
9 times out of 10 when I get this call there is glass in the pump motor. Remove the pump underneath and spin the impeller a few times. Look inside the casing for debris. Put pump back on. Also take apart the spray arm and assembly inside and clear of any debris. It should work now. I hear this problem all the time. Good luck :-)
Nov 28, 2011 | KitchenAid Dishwashers
My kitchenaid kudv24 will not drain water out
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid dishwasher kuds24sewh2. It won't drain
  • A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
  • Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
  • Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
  • Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
May 04, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Broken top water sprayer on Dishwasher
no if your mechanically inclined its easy repairman just wants a sale no matter what people say its all about the ben franklins
Nov 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water is not spraying
Plugged holes in spray bar or plugged filter in bottom, preventing water from draining down to the pump area. If the pump can't get water, it won't pump water up into spray bars. If spray bar holes are plugged, water can't get out.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
KitchenAid KUDS01DJ - Multiple Color Dishwasher Logo
322 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
