Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
When i turn my computer on i always have to turn on the num lock. i think my num lock should stay on even though i restart my computer.
    President:
  • 80 Answers
How to get Registry cleaner.
Windows XP
Click START>RUN
Type regedit
Click ok
Windows Vista
Click Start and type regedit on your keyboard HIT ENTER.
Than:
you can turn on num lock by changing "HKEY_CURRENT_USER, Control Panel, Keyboard, InitialKeyboardIndicators" to "2"
OR if that single registry entry doesn't solve your problem than go for this.
HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyBoardIndicators
Posted on Dec 28, 2008
Dell dimension 2350 num lock wont turn off
I think it's the USB port problem.. try unplugging the keyboard plug and plug it to another port.. and you can also try restarting your computer.. if problem still occur, your keyboard probably malfunctioned
Dec 13, 2013 | Dell Dimension 2350 PC Desktop
Turn on num lock laptop
Yes you can go in the BIOS and there is a setting to keep num lock on by default. To get to bios restart computer and hold delete key this will get you into the bios. Some Bios's are different you should get a prompt when it is starting up to see which key you need to press to enter setup. **Note this happens before the operating system starts up*****
Nov 13, 2013 | ASUS Computers & Internet
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Security unlock?
try pressing the buttons:
There are 3 lock symbols on the keyboard:
- the NUM LOCK that has the number 9 in it
- the CAPS LOCK that has the letter A in it
- the SCROLL LOCK that has the arrow down in it
- NUM LOCK is always turned on by default
Dec 18, 2009 | Dell Inspiron 1525 Notebook
The keyboard has a keypad, but when y turn on the num lock, the letter keys will also start working as a keypad. My computer is an HP Pavilion dv9730us Notebool PC. It has a full keyboard, with a keypad...
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
Aug 09, 2009 | HP Pavilion dv9730us Notebook
The monitor stays blank but the computer turns on fine, is it an issue with the video card or the screen? is there a way to fix this? thanks.
- Monitor plug is loose
- Maybe you only think that your computer has started. Hit the NUM LOCK key a few times, then CAPS LOCK key a few times. If you see the lights go on and off, your computer really did boot up. IF NOT, then the computer is really in trouble. In that case, unplug the computer and RESEAT the RAM modules; then try to restart the system.
Good luck and Happy Computing!
Jul 14, 2009 | Sony VAIO VGC-LS21N PC Desktop
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Keyboard
Can you please clarify this
  1. Do you keys not respond at all
  2. Do you get numbers when you want letters or otherwise letters to numbers
  3. Or does it respond only in one mode numbers only or letters only
My suggestions
  1. If its situation 1 then try reastarting your machine, and unblocking the num lock and vice versa
  2. If its situation 2 just try unblocking num and blocking back by turning on or off the num lock, its just num lock or FN + Num lock in some PC
  3. If its situation 3 just restart your computer.
Mar 25, 2008 | Acer TravelMate 361EV PC Notebook
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
387 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
