Question about HP Hewlett Packard LaserJet 3000dn Printer
Can't remove ink cartridge in F4280 printer
I've lost my manual and tried to download one and got into a big mess with my computer. I just need to replace a cartridge. That's all.
    Genius:
  • 2,120 Answers
Pull the BIG front door open all the way and let it hang open.. Instructions are in the NEW toner box.
Posted on Dec 28, 2008
Am trying to install HP 60 ink cartridges in my wife's F4280 printer. They don't seem to easily fit. Is there a readable graphic to assist me?
You have the wrong cartridges, that model uses the 300 or 300XL cartridge http://www.internet-ink.co.uk/hp-ink-cartridges-f4280/
http://www.amazon.co.uk/Original-300-Black-Ink-Cartridge/dp/B0019TUUJW/ref=dp_cp_ob_computers_title_0
http://www.amazon.co.uk/Original-300XL-Black-Cartridge-Capacity/dp/B0019TUUME/ref=dp_cp_ob_computers_title_1
regards
Jan 27, 2011 | HP DeskJet F4280 All In One Printer InkJet
F4280 DeskJet All In One Printer InkJet: There is ink in cartridges, ink light display's em...
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
May 18, 2010 | HP DeskJet F4280 All In One Printer InkJet
Ink is stuck in the printer. I can't get it out.f4280 deskjet
I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
To replace the print cartridges
1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black print cartridge
4. Pull the print cartridge towards you out of its slot.
6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing the black print cartridge, slide it into the right slot.
Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
I put new ink in my hp F4280 printer and I printed about 100 sheets and my light turned orange and it started printing slow. Can you tell does it need new ink already?
The ink level indicator is only an estimate. See page 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
The HP 60 holds enough ink to print approximately 200 pgs. By the way, it also can evaporate from the cartridge quickly too so try to keep a refill kit or new cartridge on hand.
Jun 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hi, I have an HP F4280 printer and the orange light of the color ink level is always lighting so i can't print anything (I am sure that my color cartridge is not already empty). What can I do? Oh yeah,...
There is only enough ink in the HP 60 cartridge to print approximately 200 pages. Also, the ink stored in the cartridge can dry quickly even it it's not used so you may be out of ink or the ink in the cartridge has dried up. Refill your cartridge with a kit or replace it with a new one. The ink level indicator is only an estimate any way. See pg 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jun 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink problem
Sometimes it's cheeper to get a printer on sale than buying cartarages,
However remove the ink cartarages and clean the print heads off, sometimes this works.
Verify thay have ink.
and to save a little money get a referb cart off ebay I have had good luck getting cheep ink there
Apr 25, 2009 | HP DeskJet F4280 All In One Printer InkJet
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
HP Hewlett Packard LaserJet 3000dn Printer Logo
184 people viewed this question
Ben Johnson
