Question about Belkin N Wireless Modem-Router F5D8633au4A
I need help with my belkin n wireless router, f5d8233, i need to set up a password so that only i can use it. please help.
  • 827 Answers
Type www.routerlogin.com into your internet browser url address bar.
Now press 'submit' to go to your menu. In the menu, under 'Wireless' you'll see Security, click that. Enable WEP or WPA and follow the instructions and write down you username and password somewhere safe!
Fixya!
Chris (ziraffa)
Posted on Dec 28, 2008
5 Suggested Answers
  • 19 Answers
SOURCE: I lost the password for my router, how can reset the router.
their is a reset button on the back or on the bottom u will need a neddle or something like that to reset it
Posted on Dec 23, 2008
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
KingDWS
  • 1606 Answers
SOURCE: Part # F5D8233-4 belkin wirless router need software cd
You don't need the cd. It has a connection wizard that helps set it up but you don't need to use that. You need to go to the belkin website and download the manual. That was also on the cd that's missing. Used to be a paper one in the box.
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
That will tell you how to get setup. For the most part routers run as is right out of the box. You will want to setup the wifi so you will need a SSID name to call it and then turn on the security. WEP or WPA are the usual suspects. Pick a 5 or 10 alphanumeric key. Turn on the wifi. Then you may need to enable dhcp so your computers will get ip numbers from the the router. Most of that is enabled by default on most routers. Wifi usually isn't as it requires more information.
Posted on Jul 21, 2009
  • 10406 Answers
SOURCE: F5D8233-4 belkin wireless router. I
Follow the printed (or online) instructions to do a "factory-reset" of the router.
That will use the default ID/password, and you'll have to completely reconfigure both the "wired" and the "wireless" interfaces.
Posted on Jan 23, 2011
I have a Belkin N wireless router. It's all set up but it shows as not being secured. How do I secure it? Model F5D8233-4v3
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 08, 2013 | Belkin Computers & Internet
Can't remember my password
If you have NOT changed the default password, that is:
Manufacturer Model Protocol Username Password BELKIN F5D6130 SNMP (none) MiniAP BELKIN F5D7150 Rev. FB MULTI n/a admin BELKIN F5D8233-4 HTTP (blank) (blank) BELKIN F5D7231 HTTP admin (blank)
If you have changed it, just reset the router and use above passwords.
Aug 02, 2011 | Belkin Basic Wireless Router
F5D8233-4 belkin wireless router. I don't remember the password to modify parameters, the default password "blank" doesen't work. Can you help me ?
Jan 23, 2011 | Belkin (F5D7231-4) Wireless Router
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you could give...
Check on the underside of the unit, there may be a sticker with your SSID on it. If you need to you can also reset the password back to the factory default by holding down the reset button. You can also download the instruction manual from here:
http://www.belkin.com/IWCatProductPage.process?Product_Id=509868
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 21, 2010 | Belkin Wireless Play Router (F7D4302)
Model number - F5D8233-4 if I reset the router what is the code/password
If you do a power off reset the password shouldnt change.
If you do a hard reset the code should be erased. No password until you set one. You can access your routers setting via a hardwired computer using a web browser. Go to the Belkin website to get the IP address for your particular router. Mine is 192.168.2.1. Yours might be different.
Jun 27, 2010 | Belkin (F5D7231-4) Wireless Router
F5D8233-4v3 - Belkin Wireless Router
You must configure the wireless settings of the laptop manually. It should match the wireless settings of your router. If you have wireless encryption enabled, make sure to type the network key on the wireless settings of your laptop.
Jun 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
If you tell me the version number of your Belkin wireless router , i can fix this issue.Any Routers issue contact me,, i can help you out. copy and paste this address to Browse,Mentioned below http://techhobbies.blogspot.com
Jan 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Dec 13, 2008 | Belkin (F5D72304F5D7000) Router
Looking for the general password for the belkin54g
@boblawrence6
Read page 14 from the users manual to reset the custom password & other settings.
Users manual at > http://www.belkin.com/support/product/?lid=en&pid=F5D8233-4
find the default Password at > Page 24 and reconfigure your router settings.
@munchx3mom
Surf to > http://www.belkin.com/support/product/?lid=en&pid=(CHANGE THIS WITH YOUR PRODUCT ID) *F5D8233-4*
Best regards
Screbilde
Jul 20, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin N Wireless Modem-Router F5D8633au4A Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
