Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9100LW1 blinking control light
I have a Whirlpool Duet Washer. Control lights (surrounding dial) will blink; no other functions are working. Machine will turn off, but simply does not run. I've unplugged for 30 minutes and attempted to reset using the ''cancel'' button. The problem has just occurred. Machine is approx. 4-5 years old. Any suggestions?
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
SOURCE: Duet Whirlpool Washer
You need to go to the right, to the end of cycle signal volume control button. Push it and hold it until the beep and it will go off. This is the "child safety" feature so that little ones won't interrupt your wash when they push the buttons. (and they will)
Michell~
Posted on Jul 11, 2008
  • 9 Answers
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
Posted on Jun 03, 2009
SOURCE: On my Whirlpool Duet GHW9100LW1 front loader. The
hold in the control lock button for a few seconds- it should turn the control lock off.
Posted on Aug 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer: cycle light blinks, won't run
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$@%#^
Posted on Sep 30, 2010
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
My washer won't start - :control lock" light is blinking but when I start the washer nothing happens help!
press and hold the end of cycle button for 15 seconds and that should unlock the control panel
Oct 16, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool washer ghw9100lw1 cannot pull fault codes at all
which board did you replace? If you replaced the main board it was the wrong one. You need to replace the board that is behind the push buttons
Aug 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The duet washer has been unplugged overnight. The control locked light is on and won't shut off. Pressing the end cycle button does nothing. What else can we try?
try holding the sop/cancel button for 15seconds, this should reset it but may not completely remedy the problem. after you reset it see if any other lights blink or if any other problems arise
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet GHW9100LW I turn it on and the dial light just blinks, it does not lock or start. Tried unplugging, did not work. Don't have manual. Is there a reset button?
Could be a bad lock or possibly a bad control board. I run into this all the time, working for a maytag/whirlpool dealer and repair facility. If your in a area that has alot of power outtages or surges get a surge protector after you get your problem fixed.
Feb 19, 2011 | Whirlpool GHW9150 Front Load Washer
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
396 people viewed this question
Dan Webster
Dan Webster
Sal De
