Question about Toshiba Satellite A15-S157 Notebook
Laptop my laptop's 'top' is losing it's tension and will sometimes close on it's on; won't stay up.
  • ohiobauer Nov 23, 2008
    I have the same problem. The computer is great except for this issue. If I find the hinges are they hard to replace?
  • 57 Answers
You need to contact a certified Toshiba reapir Specilist who can replace the hinges. If you do not have them changed, it might happen that the LCD screen might just fall off the hinges and you may end up with a broken Laptop.
Posted on Apr 27, 2007
  • 60 Answers
Your hinges have gone and can be easily replaced. the difficulty will come when you try to by them. Try Sparesweb.co.uk. if you cant find the hinges give them a ring.
Posted on Apr 26, 2007
Why does my Cub cadet mower blade stops and not restart?
check for worn belt or tensioner not being tight enough. check for a failed bearing on a cutter spindle.
Jun 16, 2013 | Garden
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
S7600n wireless won't stay connected
Maybe you need to be closer to the router. Try moving next to the router and see if it loses the signal. If it does, your wireless card needs to be replaced.
Mar 28, 2012 | Computers & Internet
Door won't close
Check to see if anything is restricting it from closing inside of the crevice where the wheel travels and locks. Sometimes debris from trees, dirt or rocks can clog it up.
Feb 22, 2012 | 2003 Mazda MPV
I can't keep the tension on the blade tight. After a short period of use it loosens up and won't stay on the bar.
Check threads on tension bolt may be worn or adjuster threads that bolt screws into may b worn. Odd thing is if bar plate is tight bar should not move.
Sep 03, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an hp pavilion dv 4000 and the cursor sticks and when I close the screen and then reopen, sometimes it works, but then it sticks again.
Check the cable that attaches your touch pad to the motherboard.
It may have come lose and so when you close the screen the moevement realigns it, until you move the laptop again and it comes lose again.
Jan 09, 2011 | HP Pavilion dv4000 Notebook
The lap top computer screen is loose
Those screens tend to lose their tightness as time goes on from all the opening and closing. Regrettably, there isn't much to be done with them except replacement of the part. You can jury rig it but that's about it. I,too, had a zv5000 and experienced the same thing.
Please don't hold my bad news against me when you rate my answer! ;-)
Jan 11, 2009 | Computers & Internet
How do I know which tension to adjust?
top tension is the culprit raise pressure foot before you thread machine so thread passes between discs give this a try .
mary h
Jan 06, 2009 | Sewing Machines
Toshiba Satellite A15-S157 Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
