When i plug my ipod into my bom box.. it goes Charging-Not Charging.. really rally fast ovr and over again.. i tried it with 2 of my ipods. and still the same.. is it my boom box thas the problm?
    Sergeant:
  • 250 Answers
Hi there
Wow! That's awesome! Well done!!
The problem, based on the fact that it is happening identically to 2 different ipods, is definitely your 'boom box'.
Check the main usb connector of the boom box
All the best
Sean
Posted on Dec 28, 2008
Have a new ipod nano 6th gen 16 GB...and it seems like the battery goes empty really fast. It also doesn't seem like you can really shut it off like my old ipod nano.
first you should let it charge when not in use, apple makes there batteries cheaply and the more it hold a charge the longer the battery will last, secondly you can't shut off your ipod nano, sorry, lots of people complained about this, when you press the button it goes into standby mode and still draws power it will turn off after 36 hours of non use. so i recommend that when your ipod is not in use it is plugged in charging. good luck
Feb 15, 2011 | Apple Audio Players & Recorders
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
1.The battery indicator on my touchipod 32G is not charging. When plug into power point. It indicates charging then goes off after few minutes. 2. Battery indication is low so I am not able to open or...
Simply plug it to your computer since whenever its plugged to any usb slot of a computer it automatically charges the iPod. Windows works perfectly with iPod but you have to install iTunes software to enable one to transfer music to & from the iPod.
Nov 23, 2010 | Apple iPod touch
My iphone is not turning on. It is jail broken the problem is whenever the iphone goes off i have to jailbreak it each time. Now also i have dome the samething but its not working. Its not turning on.
Try to reboot the iPod, just in case it has crashed
  1. Hold the top button and the home button for about ten seconds.
  2. A bug can stop the screen from displaying, sometimes you can reverse the problem by doing the reboot. If you still see nothing on the screen, try to plug the iPhone in to the computer and try the reboot method again.
If you are still unsuccessful in turning on the iPod, but the iPod shows up in iTunes, try restoring from iTunes to fix any bugs causing the issue
  1. Plug the iPod in to your PC, go into iTunes and click the iPod's icon on the left side of the screen.
  2. In the iPod Summary Screen, click on the restore button and agree to the prompt asking if you really want to restore the iPhone's software.
If you are still unsuccessful in turning on the iPod, but the iPod doesn't show up in iTunes, try putting the iPod into recovery mode
  1. You can put the iPod into recovery mode if it has a charged battery.
  2. Start by holding down the home button before connecting it to iTunes, then continue to hold the button until iTunes recognizes that the iPod's in recovery mode.
  3. Recovery mode allows you to perform a restore when you're when an iPod fails to turn on or display anything on the screen.
Jun 30, 2010 | Apple iPhone Smartphone
My ipod nano will show its charging but its really not!
when I bought a ipod I researched them first. The lifetime of the batteries in the ipods and mp3 players are only about 2 to 3 yrs, depending on how many times you recharge.
Aug 08, 2009 | Apple iPod nano
IPod Nano 2 GB no power
Try pressing the menu key and center key at the same time and waiting until the gray apple screen comes up. This will reset your settings but I know whenever my iPod goes funky I just do that and it's fine. If that doesn't work contact your local Apple store.
Aug 24, 2008 | Apple iPod nano
Help me fast
Update the firmware using iTunes to replace the information you have removed from your iPod when you have formatted it.
Mar 11, 2008 | Apple iPod MP3 Player
Loading videos to ipod nano 3rd generation
iPod Nano accepts only MP4 format video, please make sure your video is compatible with iPod Nano. If your vide is MP4 video, please follow these steps:
1. Open iTunes and click "File" to add your videos to iTunes library.
2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply", done.
If your video isn't MP4 format, you need third party software to convert video to MP4. You may try an iPod converter developed by Aimersoft; it can convert videos to iPod Video and iPod Nano, iPod Touch and iPod Classic with fast conversion speed and excellenrt output quality, that's really good for me, you can have a try, here is its official download link
http://www.aimersoft.com/ipod-converter-suite.html
Hope it helps.
Jan 16, 2008 | Audio Players & Recorders
How do i sync video's to my I-pod
enable an option called "Include Music Videos" in my iPod settings. Apparently, this feature is disabled by default when you update to iTunes v7.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
64 people viewed this question
 Grubhead
Grubhead
