Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Convergence. I hope you can help me. The screen on my hitachi 51F500 is distorted and blurry, esp in the left hand corner. Any written words will appear as rad, blue and green, just not on top of one another. I went to manual convergence and the grid is also distorted in the left hand corner. It looks similiar to a sinusudial waveform. The majic focus function stopes during the green alignment and displays a number 5. From the research I have done tonight it appears that I need new convergence IC's. If you could confirm that I need the IC's I would gladly purchase them thru your shop. I haven't taken the back off the set yet - I am hoping it is obvious where the IC's need to go - any help would be appreciated. Thank you, Tom M.
    Sergeant:
    Champion:
  • 375 Answers
Possible covergence ic are faulty and that your sensor is either sensing it or is at fault also,can the pattern be corrected with adjustment,if not your amps are the fault.
Posted on Sep 09, 2007
52 rca bottom left corner words are blurry but fine every where else when you play a video game It almost looks 3d to
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Left side of sreen is blurry/halo effect. Right side is normal. Magic focus stops when it gets to green and flashes green number 5 on bottom left of screen. (Hitachi 2003 51" projection HDTV)
SET uses two of the STK-392-150 convergence chips for this, both need to be replaced and set adjusted.
Parts cost on EBAY will be under 25 dollars. I can help if you are do it yourself person. A shop will get 250-300 for this but you can do it for much less.
Can I assist you?
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
Wavy colored line at upper right corner of set seems like something is pushing from top left and distorting picture from that direction.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 13, 2010 | Hitachi 51F500 51" Rear Projection...
My Hitachi TV Model #51F500 is showing shadows and double lettering (in other words a terrible picture). Please help.
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 51F500 51" Rear Projection...
Red Alignment problem on a Hitachi 51inch rear projection tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51f500(flicker+warp)
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Jan 23, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Jan 25, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
