Question about Maytag MDE2600 Electric Dryer
High pitch squeal
While the dryer is running, we are getting a very high pitch squealing. Any ideas what it could be, not sure where to start.
  • kinnadz Dec 29, 2008
    when the dryer is running there is a high pitch noise and it stop and it come back again just wonder if there is something stock in there in the drum
  • 65 Answers
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Posted on Jan 26, 2009
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Dryer makes squealing noise when running. What's wrong?
the idler or tensioner wheel that your belt rides on has a bearing in the center of it. This bearing is going out causing the high pitched squeal your hearing
Jan 23, 2011 | Fisher and Paykel DGGX2 Dryer
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My dryer has a high pitch squeal when starting up. It would go away after a few minutes when it warmed up but now the squeal is getting worse and lasting longer
Kevlar 'slip strip' on which the front of the drum runs may need to be replaced. Try turning drum gently by hand to guage whether or not it is turning freely.
Feb 28, 2010 | Dryers
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
2006 AUDI A4 2.0 HAS A HIGH PITCH SQUEAL AT IDLE TAPERS OFF AT HIGHER RPM -THEN MAKES A WHINING NOISE WHEN ENGINE IS SHUT OFF --ANY IDEAS?
hey not sure if its totally right but the high pitch squeal at when its idleing could be the tentioner pulley bearings on the engine belt not sure about the whining noise when its shut off
Oct 04, 2009 | 2006 Audi A4
High pitched squealing noise when i start engine
have Your alternator belt checked for the propper tension:]
Jun 17, 2009 | 2003 Nissan Frontier Crew Cab
Maytag MDE2600 Electric Dryer Logo
249 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
