Question about Universal Remote Control Remote Control
My aeros universal remote was working fine...
I can turn on and off the tv using the remote. The volume/mute button works as does the Main button and each of the buttons beside the screen, but the channel, guide, info, exit buttons don't respond to touch. Any thoughts on what could be wrong?
dmathwizard
  • 113 Answers
SOURCE: Won't turn tv on & off and won't change the volume
Reset the codes using the manual
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
If not get a new one.
Posted on Mar 05, 2008
leethedeuce
  • 4472 Answers
SOURCE: All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
Posted on May 28, 2009
rulds2008
  • 3866 Answers
SOURCE: codes not working, need to bring up menu on tv
Yes , Most Rca will not work so you need something that has more codes, Let me give you a website to checkout www.remotes.com, These people will not only help you but they will find a remote that will work for your TV, Give them a call as well they do have codes and remotes for all TV's you be happy you did. Do not shoot the messanger give a good rating.
Posted on Jul 10, 2009
  • 8 Answers
SOURCE: Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Posted on Aug 19, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: How to program to use with my universal remote to work?
YOU HAVE TO HAVE THE PROSCAN REMOTE OR BUY BETTER REMOTE
Posted on Aug 24, 2009
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
Philips Magnavox Universal remote and mute control on Toshiba TV
Ha.....flippped a reset-type button on back of TV set...all is now fine....
May 07, 2009 | Philips Universal PH301S Remote Control
My volume and mute button dont work on my sky remote
panasonic
please follow the steps below:
TV
RED + SELECT
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 06, 2009 | Universal Remote Control Remote Control
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Muted on Cerain Channels on Zenith SE2795W TV
Somewhere in it's lifetime, a user has set the 'user preference' to 'mute' while this channel was active. I don't know your specific set, but most TV's need a remote to work 'mute'.
Second hand set?
[A] check all buttons on TV for a crossed-out speaker symbol, or
[B] buy a universal remote and select pin for your set. Then,
Try these:
ZENITH - 000,001,004,023,038,058,059,064,073,121,135,136,153
Oct 11, 2017 | Panasonic DMR-EH60 DVD Recorder/HDD...
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Comcast remote
true most all the new lcd panels use a new code that no remote has.
about all you will be able to find is the on/off code if you scan for it.
Jan 06, 2008 | RCA Universal Remote Control
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Universal Remote Control Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
