Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor Logo
rich fogg Posted on Apr 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor I have a emachine with a samsung syncmaster 151v monitor. I just reformatted my hard drive using Windows xp pro. My monitor went all to hell. I cannot change res from 640 x 480 and 4 colors. I tried reinstalling driver but it just kept saying that the program had to close. I went through the troubleshooting and it is telling me that there is no adapter installed. Can anybody help.
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Nov 24, 2007
Anonymous
Expert
Level 2:
Answers
91
Questions
Helped
46053
Points
242
It's a problem with the graphic card, not the monitor, try finding another driver.
I am trying to connect a samsung syncmaster 151v to my computer and the moniter reads video mode not supported what am i doing wrong?
Your resolution is set to high for the monitor to accept it. Go into control panel and click on Display then click on display setting and lower your resolution keep going lower until your monitor accepts the resolution size and your monitor should work for you.
I hope this helps you out any positive feedback to me would be greatly appreciated.Thank you
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
2answers
I bought a used Samsung Syncmaster 151v and had it for only a few hours before a thunderstorm knocked the power out. When I went to turn the monitor back on, all I got was a blinking green light and no...
This can be a fuse or the CRT tube or even a transistor, I would rather try to find a technical shop that can determine the problem, just be carefull that they dont charge you to check. Thus it will be for yourself to establish if it's worth it. Most of the time it is.
Good Luck
After installing Windows 7, my SamSung SyncMaster 2233BW has very poor picture. Regards.
Yes,Because Windows 7 is taking the higher amount of Ram.So the videos will be very poor and also system will be slow down.You must increase your Ram to 1 GB. (or) Use windows xp.
Thank u...
Installing XP home edition with SP2: Won't recognize hard drive
Hell, Sorry to hear your having problems your analysis sounds correct but lets make sure it's not something else first. Can you give me more details on the drive Brand, IDE/SCSI, model number. Do you have access to a computer with a CD burner?
Mother board
do you mean by xp black OS? have you let others fix your computer like reinstalling or reformatted your computer? if so, they might have used a fake windows..
1helpful
Downgrade from Vista to WinXP Pro
No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
Please take a moment to rate as fixya. Thanks!
EMachines PC that has not yet been thrown out the window, but....
If this computer came with XP Home, and you don't have a disc, then they would have put the restore files in a separate partition on the hard drive. Do you have the manual for the pc? It's possible to recover your system without losing everything. What happened when you used the recovery disks and XP Pro?
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
