Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Hoover Savvy Belt
Happy Holidays.
Trying to take your helpful advice on replacing the belt. The infamous sticker screw was a real help. I'm wondering if the belt goes on both sides of the spool that is in the middle. I say yes but my wife says not so. I can't however get the spool out to have the belt go on both sides. I'm at a stand still. It looks like it has room to go through and I doubt the friction of it rubbing on itself would be productive over time.
Help.
Thanks so much. It's much cheaper to try to do it yourself.
A
  • 281 Answers
Put the belt over the brush roller first then put the brush roller on then you can start one side of the belt on the motor shaft and turn it will make its way onto the gear on the motor
Posted on Apr 23, 2009
  • PETE GALATI
    PETE GALATI Apr 27, 2009
    no just one side its an idler pully,helps keep the tension on the belt
How to replace geared belt on Hoover Savvy U8171
Tom, This one is tricky. First get the belt on the geared motor pully, and then insert the roller through it. You will have to roll the brush toward the body of the vac to have enough room. Patience is the best on this model.
Jan 10, 2010 | Hoover U8171-900 / U8172-900 / U8173-900 /...
How to install a U8172-900 belt
your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Sep 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I install the timing belt on my Hoover Savvy Vacuum? Modle # u8174-900 Where is it located?
http://www.vacshopusa.com/hoover_savvy.htm
This is a parts schematic for your hoover savvy. You have to take off the brush guard on the bottom and also the cover on top (there is a screw under the round hoover logo). You will then see how the belt is attached. Very easy to do. Hope this helps
Jul 02, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
How do you replace the belt on a Hoover Savvy?
Take off the bottom plate, then remove the screws to remove the top cover, turn vac over, remove the hoover emblem, there is a screw there to remove. The top should come off, the easiest is to loosen the motor to give you some slack, then replace the belt and reasemble.
Sep 04, 2008 | Vacuums
U8174-950 SAVVY BEATER BAR NOT TURNING HOW DO I REPLACE BELT OR FIX BELT AND WHERE IS CLOSE SUPPLYER IN EDMONTON ALBERTA
Take the screws out from the plate covering the brush roll, look for maybe 2 screws from the bottom to take out, then turn vac over, remove the Hoover emblem and remove the screw there, now the top will come off and you can get to the belt and brushroll. Check around your local repair shops for a cogged belt for the Savvy. I would think someone would stock it. Alot of Sew and Vacuum stores also service and have parts.
Jun 10, 2008 | Hoover Vacuums
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Belt change on savvy upright
Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
May 11, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover savvy changeing belt
There some screws on the bottom to take off, then turn vac upright, under the round Hoover logo sticker is another screw. It is just a sticker, so will peel off. You can work the belt onto the motor pulley, or unscrew the motor, put the belt on the pulley, then reinstall the screws to hold down the motor.
Jan 06, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Need help with my Hoover Savvy U8172-900 -- agitator does not spin when on
You probably jammed the roller brush and the gears on the motor stripped the teeth out of the drive belt.  You have to take the bottom and the top covers off the lower unit to replace the belt.  There is a hidden screw that keeps you from taking off the top, thus creates work for authorized Hoover repair shops.  You'll find that screw under the round red label in the center of the top of the lower section.  Peel it up and there is the screw.
Nov 30, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
178 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
