Question about Sony PlayStation Portable (PSP) Console
Psp gone really slow
Psp gone slow and takes about 5 mins to load games then the games are slow to play the systems is slow as ever cant get on anything is there any upgrades that i can get to reset this the defualt system is doing nothing i think its made it worst cheers if any one can help thanks
  • daneil_tonks Dec 28, 2008
    no already got memory stick in with 1/2 a gb this is not the problem sorry
    Problem Solver:
  • 10 Answers
Try getting a memory stick for it.. so then lots of the memory is free'd up
Posted on Dec 28, 2008
Ive come to realise that most of the older game for psp made into download format are currently running slow in framerate,rendering and gameplay no matter what psp system i use,examples:gta vice city...
The big difference is that the PSP is having to pull everything (in terms of music, graphics, etc.) from the internal memory unit of the PSP itself. This takes processing speed and therefor slows down the entire unit. When playing a game off UMD, most of the information is being drawn from the UMD itself, which takes substantially less memory then running from the system itself. There's really no way to fix this until they get a PSP that has a beefier processor in it.
Aug 13, 2010 | Sony Ratchet and Clank: Size Matters for...
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Games work really slow on psp merory stick
maybe your game format is CSO... CSO is a compressed file... which means a bigger time to load for the psp from the memory stick...use ISO.. but note that when using ISO the file is bigger than CSO and may be even bigger than its expected size
Jul 25, 2009 | Sony PlayStation Portable (PSP) Console
Slow Motion Loading Of All Game On My PSP Console.Don't know why?
just press select button then u'll fine cpu speed make it default.
Very slow interface but no such problen when paying a game
This happens when you have a dirty psp game loaded, perhaps it needs cleaning? It can also happen if somehow the system files have become corrupted, if this is the case you must reinstall the PSP software or try updating it by connecting to the internet with your psp and going to the update function.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Slim...
What should i do when my psp goes slowly?
Actually that always happens with the psp depending on the game you wanna play. I found out that some games take a whole lot of time to load up than other games. For example Mightnight Club 3 takes ages to load up but if you play soduku or Daxter for example it takes a whole lot less. So my sujestion is patience, patience, and more patience.
Sep 18, 2008 | Sony PlayStation Portable (PSP) Console
All psp games in my psp runs in slow motion
man the "333" solution actually works pretty damn well!!! Thanks man!!
Mar 03, 2008 | Sony PlayStation Portable (PSP) Console
PSP Wont play games, and is going slow on other things! [HELP]
you,ve damaged the UMD Drive, or Laser.
hence disk read errors.
you,ll have to obtain a replacement UMD Drive ( e-bay )
Or alternatively you could look into firmware flashing and pandoras Battery.
This way you can play games from a memory stick.
Mike @ Compurepair.
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
131 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
