Panasonic 1080i HDTV without picture
Picture went out. Attempted to turn on TV but only the light switched from red to green without any picture or sound. Lamp is OK
    Problem Solver:
  • 10 Answers
Try refunding it.. becasue there is deifinatly something rong with your TV
Posted on Dec 28, 2008
How do I know what parts to get to fix it
Have you replaced the lamp recently? they can fail if they are on when the storm happens? Please post your model # for more info.
Apr 21, 2015 | Panasonic Televison & Video
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Aug 09, 2010 | Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Panasonic HDTV 1080i 52inch TV that is 6 years old. When I turn it on, the green power light just blinks and there is no picture at all. Any advice?
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
Oct 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My 1080i has a triple picture, can you help?
It definitely can be fixed the IC chips (called STKs) that line up the images from each picture tube are failing.Sometimes a fuse or resistor go out along with the chips. The parts would cost around $100 + whatever labor charge if you hire someone.
Apr 29, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Setting Polaroid 32" HDTV for 1080i
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
