Question about Maytag MCD2257 Side by Side Refrigerator
Maytag mcd2257kes Ice maker works fine for cubes and water but not crushed. I looked inside and the cube setting turns the rod in the ice bucket counter clockwise. When I select crushed, it turns it the same way instead of clockwise which wold crush the ice. How can I fix that?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and the model number.
Thanks for using FixYa.
Posted on Jun 03, 2010
My maytag refrigerator crushed ice will not switch back to cubes
Try replacing the ice bucket. That has the teeth and gears that crush the ice up. It could be stuck. If not then there's a solenoid in the back of the freezer that switches the ice bucket from cubed to crushed. You'll see the rod in the ice bucket slides into a square hole that moves up and down. That's it there.
Aug 25, 2016 | Maytag Refrigerators
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice maker crushes ice will not extrude cube cubes
Your ice bin is out of alignment. Pull the ice bin all the way out and re-insert it and make sure it locks in place. When you re-insert the bin,look underneath the bin. You will see a metal rod. It must go INSIDE the yoke at the rear of the freezer, NOT under the yoke and NOT over the yoke. In the yoke.
This is a common problem and will happen again. The ice bin has a way of dislodging itself. If the rod is not in the correct position you get crushed ice regardless of the setting.
Sep 29, 2009 | Frigidaire Refrigerators
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Oct 11, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag MCD2257 Side by Side Refrigerator Logo
106 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
