Question about RELIANCE ELECTRIC WATER HEATER
Residential electric hot water heater throwing br
I have a Reliance eletric water heater, 30.0 gal., approx. 4 yrs. old. Woke up the other morning no hot water, pushed the red button, everything was cool. Happened again the next 2 days but on the 3rd day the red button would not reset. The breaker was thrown so I tried to reset the breaker and sparks and pops shot out at me. My husband who wasen't home at the time I attempted to turn the breaker back on was certain I must not be smart enough to flip a switch so he tried it and the same thing happened to him. So..is this a h2o heater prob? or an electrical issue or both? Thank You for your time and expertise.
Sincerely,
Stacey James
Thank You
    Scholar:
  • 68 Answers
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Posted on Dec 28, 2008
No hot water
It is probably the thermostat. I would suggest replacing that next.
Feb 24, 2014 | Reliance & 40 Gal Electric Mobile Home...
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Woke up to no hot water changed out both heating elements and both thermostats meter says wiers are hot checked breaker its got power still no hot water any suggestions
Water heater can test for power, but is only receiving 120V instead of 240V.
Test that upper thermostat is getting 240V across top two screws of thermostat.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Reliance & 40 Gal Electric Mobile Home...
The water temp is set to the lowest thermostat setting; however, the water is extremely hot and often throws the safety breaker loaded on the heater itself...... I reset the red button and it heats.........
probably has lime and mineral deposits on thermostat and is not getting a correct reading turn off water supply and electrical - drain tank remove screws to heater elements and if build up try cleaning or if to bad replace same with the stat
Feb 15, 2010 | RELIANCE ELECTRIC WATER HEATER
50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
Describe your Reliance & 30 Gal LP
TURN OFF THE GAS VALVE AND WATER TO THE TANK REMOVE THE PIPES FOR THE DRAFT USE A SHOP VAC AND CLEAN THE DIRT AND DUST FROM THE INSIDE OF THE DUCT WORK ALSO WHERE THE BURNER IS LOCATED YOU CAN VACUME THERE ALSO AND REINSTALL THE DUCT TO THE FLUE
Aug 23, 2009 | Reliance & 30 Gal LP Gas Water Heater
I need a new water heater, I live in a mobile home, 9yrs.old.
you can use a residential water heater, just make sure it's the correct amperage/power draw for your circuits.
Jun 20, 2009 | Reliance & 40 Gal Electric Mobile Home...
RELIANCE ELECTRIC WATER HEATER Logo
230 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
