Question about Swanson 8 Inch Sliding T Bevel
How do I use an 8" T bevel?
I have some chair railing I need to put up and the walls are not at 90 degrees. I have an 8" T bevel but have no idea how to use it to get the correct angle. Can you help?
  • peter van hoose Oct 27, 2011
    im trying to get the angle on my roof for tow by fours ribs for framing?
  • 8,197 Answers
Put it against the wall so it touches both walls. Then lock it in place with the nut. Next if you have a power miter saw lay it on the table and move the blade so it lines up with the angle thay you have then it will give you the angle for the cut.
Good Luck
Posted on Dec 28, 2008
Whish piston ring is the top one
Hi, Anonymous there literally dozens of top ring designs depending on the manufacturer that being said and being a Harley Davidson Technician I can only give you advice on a 4 stroke 3 ring set the top ring on premium ring sets will usually have a silver plasma coating on the outside edge and a dot on the flat side the dot always faces up the second ring will be all one color and may have an inside bevel the bevel always faces down if there is no dot. The third ring is usually a 3 piece oil control expansion ring and the skinny rail rings can go any side there is no top or bottom bevels or dots. install the rails gap 180 degrees apart install the top and second ring gaps 120 degrees apart do not oil piston rings a few drops of clean engine oil smeared on the cylinder wall with your fingers will be sufficient. I "STRONGLY" recommend you download a service manual online for your particular year, make, and model they are usually free in pdf form or at the most between $5-10. Good luck and have a nice day.
Dec 30, 2015 | Motorcycles
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Is there a way to adjust the set pin to get a true 90 degree bevel?
set the blade at the built in 90 degree lock, now use a square and adjust the fence (usually two bolts visible on top of the fence) to the blade at 90 degrees....there are some shops which offer this service under a "tune-up" or calibration.
Jul 07, 2012 | Hitachi C12RSH 12" Sliding Compound Miter...
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
Do you lay the handle long wise against the wall or the end of the handle??
A sliding bevel is used for transferring an angle. What matters is the angle created between the handle and the slider. For example, if you wanted to cut a piece of wood to fit in a corner but that corner is not 90 degrees true. You would loosen the nut, place the center of the bevel in the corner so the edge of the handle lays flat on one wall and the edge of the slider is flat against the other wall. Tighten the screw on the bevel. Now you can lay the bevel on the piece to be cut and mark the exact cut line so the finished piece will fit perfectly.
The sliding T bevel can also be used for setting an angle by using it with a protractor. lay the bevel on a protractor, lock the screw in place at the desired angle, then lay the bevel on the work piece and mark the cut.
Dec 31, 2010 | Swanson 8 Inch Sliding T Bevel
How do I cut moulding for steps? What do the numbers on the table saw mean....like 22.5 degrees?
By default people keep their blade set to 90 degrees - perpendicular to the table. There are times you need to cut a beveled edge which is not 90 degrees.
The numbers on the saw refer to the bevel angle or how far from 90 degrees your blade is tilted.
http://www.askthebuilder.com/557_Stair_Trim_Molding.shtml might answer some of your other questions.
If this answer helped, please vote for it.
Jun 08, 2010 | Saws
How to cut compound miter on a flat surface, where can I find the chart.
It's a combination of an angled mark on the board and the bevel on the saw set to the proper angle. What are you trying to cut?
Jan 28, 2010 | Delta Saws
I have a 10" ryobi table saw and my bevel will not return to the 0 degree position. I can change the angle, but I can not get the blade to sit straight up and down. I can push it almost to zero with much...
I have a Ryobi folding table saw and I learned how to adjust the bevel through trial and error. There are two allen key machine set screws in the top of the table. One for 90 and the other for 45. I backed the 90 screw off past 90 and than set the blade exactly at 90. Now I screwed the allen screw in to touch the blade. It seemed to work for me. Mind you it will have to be checked often to insure a perfect cut. Good luck.
May 03, 2009 | Saws
Swanson 8 Inch Sliding T Bevel  Logo
1,498 people viewed this question
Top Swanson Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Swanson Measuring Tool and Sensor Expert? Answer questions, earn points and help others
