Question about Dell Inspiron B130 Notebook
SYSTEM DOESN'T RECOGNIZE NEW MEMORY MODULE
I installed a memory module to my Inspiron B130, however the system doesn't recognize de extra memory
    Novelist:
  • 101 Answers
Memory modules must be the correct type and speed, and be within the specifications for the laptop. Just because it fits in the slot doesn't mean it will work.
The Dell inspiron B130 has 2 slots. Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. if you tried to insert a 2GB module, it will not work.
If the module is within these parameters, remove and re-seat the memory, and try swapping the modules from one slot to the other. It may be a bad slot.
Posted on Dec 28, 2008
Memory Upgrade Not Recognized
bad sign if the memory slot is damaged then there is probably with the motherboard then in saying that try getting 2gb of memory and insert it in to the original slot where you had the original 1 gb
Jun 18, 2012 | Dell Inspiron B130 Notebook
Dell Inspiron B130- Memory installation in second slot
RAM modules in laptops are secured by spring clips on both sides of the RAM module.
To release the RAM module press the clips away from the RAM module and the RAM module will pop up at an angle. You can then pull the RAM module away from the memory slot.
Insert the RAM module in the slot, push it into th slot and then press the RAM module down until the clips on the side lock onto the RAM module.
Jun 04, 2012 | Dell Inspiron B130 Notebook
I just upgraded memory and my b130 only reads the A slot
Re-seat the memory modules. If that doesn't work try swapping the modules to see if one is defective. If both modules work in slot A then you have a damaged slot B memory slot and the motherboard needs to be replaced.
Aug 27, 2011 | Dell Inspiron B130 Notebook
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Just bought 1 gb of ram for dell b130. When i turn on the computer the cap and scroll lock lights flash and computer just turns off
this problem is down to mismatched ram. did you install the new 1gb of ram with the ram that was already in the laptop. if so you will just have to ues one or the other. hope this helps. leave feedback
Jun 21, 2010 | Dell Inspiron B130 Notebook
My Inspiron 1525 does not recognize the memory I added. It had 3GB, I removed the 1GB and added a 2GB. When it did not register the additional memory, I put the old one back in and it now does not...
Once you change the ram, you have to boot to the system setup so that the BIOS can recognize the new module.
When inserting the ram module in the slot, it should be at a 30 degree angle to the system and inserted till the golden contacts can not be seen looking straight down at the slot. Then press the module down until the retention clips click. The top edge of the contacts should then be barely visible.
Once the RAM has been properly inserted, then boot to the system setup, exit then boot to windows
Oct 01, 2009 | Dell Inspiron 1525 Laptop
Inspiron B130 USB Ports Not Working
Try going into control panel and then system and the hardware and then device manager look for the usb ports and delete them, then reboot the system ,they should be there.
May 31, 2009 | Dell Inspiron B130 Notebook
Battery not recognized
If the battery is beyond charging, it might not be recognized but, all that I've seen could recognize it . There are 6-8 terminals on most batteries. 2 of them close the circuit indicating a battery is in place. If you have access to another battery that is made for your computer, try it. If you still don't have a battery indicated, you could have a problem in the charging system or the bios.
Feb 20, 2009 | Dell Inspiron B130 Notebook
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
259 people viewed this question
Alun Cox
