Question about Bose Cinemate Digital Home Theater System Speaker
Cannot find a device code for ATT Uverse DVR cable box
For the universal remote
  • 4 more comments
  • matt6foot4 Dec 30, 2008
    I'm also looking for a code for ATT U-Verse cable box.
  • CatFshHunter Jan 03, 2009
    the Bose lifestyle 30 system doesn't list Cisco as a brand for the DVR, and one would still need the remote code in addition to the brand, right? I called AT&T and the rep said there isn't a code for their box which is doubtful.
    any ideas how to make the Bose remote control the AT&T Uverse DVR?
    thanks!
  • Anonymous Mar 14, 2009
    no code for cinemate remote that will operate att uverse (motorola) cable box
  • Anonymous May 13, 2009
    Dude,
    Thanks for the help...First try & it worked!!! I believe that most peeps do not know that you have to release the volume controls 1st
  • pam529 May 11, 2010
    Do you know how to set up the BOSE remote to control the AT&T Uverse cable box?
  • Judy Miller May 12, 2013
    can I program a cox cable remote to work with Uverse dvr system
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Posted on Dec 30, 2008
  • LEONARDOG685 Jul 22, 2011
    I FINALLY FOUND THE CODE TO PROGRAM INTO YOUR BOSE CONTROL REMOTE TO CONTROL THE UVERSE BOX IT IS 02045! TRY IT IT MIGHT WORK!!!!! HONESLTY I SPENT HOURS, BUT I FOUND IT!
It doesn't work with a Bose Lifestyle 18 Series II.
Posted on Jul 27, 2009
  • Jose Ortega Dec 27, 2011
    02045 worked for my AT&T Uverse Cisco cable box. Thank you!
What is the code for my sony tv remote control DVD VCR COMBO
Ray, Check the attached links,remote codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sony eSupport Remote Control Codes Programming Select Model
New 3 digit codes for DVD VCR DVR SAT TV VCR TV DVD DVR CABLE and DVR DVD...
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
Mar 08, 2016 | Sony Televison & Video
Can a cox dvr remote be progranned to operate my ATT Uverse box? Lost my Uverse remote and dont wanna spend $ on new remote if poss
If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine and half Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
May 12, 2013 | Televison & Video
My att universal remote will not work, I used all emerson"s codes
my att remote does not work the att dvr cable box unless I'm within one inch of the DVR why?
Jun 25, 2009 | Zenith B19A02D 19" TV
Att uverse codes/Cisco dvr box
is ipn 330hd the model number for the cisco scientrific atlanta box
Apr 28, 2009 | Televison & Video
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
SOrry for your plight, the Bose staff are correct, they do release occassional firmware updates via a DVD or a CD throught their costumers mailer. If you are not part of this mailer, you may go to any Bose service center and request the latest update disc for your Lifestyle 18-II system. Udpates should be able to help you sort out your problem.
Glad to be of service...
Jan 21, 2009 | Bose Lifestyle 18 System
Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Aug 08, 2008 | Maxent MX-26X3 Television
Bose Cinemate Digital Home Theater System Speaker Logo
9,691 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
