Question about Amana AFD2535DES French Door Refrigerator
Amana Refrigerator cooling motor clicks on and off frequently
Hello - I have an Amana Refrigerator w/bottom freezer drawer. Problem: When I open the door to take something out of the refrigerator and then close the door the cooling motor clicks / turns on and off about 4 or 5 times before the motor runs consistently until the temp. within the refrigerator gets to the correct temp. for the motor to stop.
Can you tell me what the problem is and what part I need to replace? Also, please tell me where the part is located within the refrigerator?
Thank you.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
Maytag317
  • 1136 Answers
SOURCE: Amana refrigerator not running but light and water dispenser work
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jun 14, 2009
SOURCE: Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Posted on Jun 23, 2009
Just opened my freezer drawer (bottom freezer) and it's covered with a heavy layer of frost. Was OK yesterday. What's wrong?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Amana Refrigerators
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Veggies in crisper drawer are freezing,what is causing this?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Amana AFI2538A Bottom Freezer French Door...
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
95 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
