Have a kenmore washing machine (top load) won't spin without help and makes a grinding gears type noise when it does, do you have any troubleshooting ideas on this?
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 90top loader,wont spin or pumpwater all out just makes a loud grinding noise,,
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer Mod. 110.24832200 Grinds when in spin mode.
MORE THAN LIKELY ITS A MOTOR COUPLING PART# 285753A LOCATED BETWEEN MOTOR AND TRANSMISSION
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
