Question about Dahlquist QX-4A Main / Stereo Speaker
Blown fuse on sub woofer
Dalquist PDQ-1200. can't read the size of the blown fuse. what size fuse would you suggest? Don't want to blow up the sub.
1 amp 250-volt from radio shack #270-1021
Posted on Jul 24, 2009
NX-4CD CD is read but no audio out
You need to be more specific. What have you tried so far?
Sep 16, 2014 | TDK Audio Players & Recorders
Ps-1200-A sub woofer will not power up
Probably a blown fuse. If there's not one on the face of the amp, pull the amp and check for one next to the power cable.
Nov 08, 2010 | Paradigm Titan Speaker
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
Keeps blowing fuse in woofer
Seems like the wires inside the woofers are crossed. Open the sub and make sure that there are no bare wires touching. If everything seems OK then the circuitry inside is blown.
Dec 13, 2009 | Infinity TSS-1100 System
What size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
Onkyo sub woofer
You will only blow fuses and resistors if there is a short of some kind you can change fuses, resistors and capacitors all you like if you don't find the short they will just keep on blowing. It maybe something as small as a bit of conductive material or fluff or dust on chip board wipe board down make sure it is clean (a clean toothbrush is perfect) and there are no signs of burns on either side of the chipboard befor you change anything. If there are burns or greenish build up clean them with some metho or water on a cloth not to damp though and make sure Burn or corrossion hasn't taken off the protective layer on the board.
Then try new fuses. Hope this helps you
Jul 25, 2008 | Onkyo TX-DS676 Receiver
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
Dahlquist QX-4A Main / Stereo Speaker Logo
489 people viewed this question
Top Dahlquist Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dahlquist Audio Player and Recorder Expert? Answer questions, earn points and help others
