Question about Reddy HEATER RH125T 125,000-BTU PROFESSIONAL SERIES PREMIUM PORTABLE KEROSENE FORCED AIR HEATER W/TH...
RH125T won't fire
Is there any way i can check the igniter? or do i just need to buy a new one?
  • Anonymous Mar 24, 2009
    ignitor light comes on and heater won't start how do I know if it's a bad ignitor or the circuit board?
  • 232 Answers
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Posted on Dec 29, 2008
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
False starts and smoke
Hi and welcome to FixYa, I am Kelly.
Download this service manual
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
and follow the fails to ignite steps
or ignites and does not stay lit steps.
Most likely either the photocell is very dirty, defective or mis-aligned.
The well written service manual will help you immensely to resolve your problem.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater on/off sitch doesnt work, can i jump the wires to test if thats the problem?
Yes, you can, but make sure to use the proper gauge wire. Don't want to start a fire.
Jan 26, 2011 | Reddy Heater RH125T Kerosene Forced Air...
I have a Reddy heater 125T and the transistor for the ignition is burned into, i was wondering if it is possible to solder a new transistor to the board, and if so what would be the part number for the...
Yes, I have done it and got transistor from a electroic story. took old one to them and they match it. When soldering it on use very little heat not meld the other solder tracks. Ken'Repair
Jan 22, 2011 | Reddy HEATER RH125T 125,000-BTU...
125btu reddy heater, somene mixed some gas in the heater and now it won't ignite. how to fix??
Drain it clean it out real good clean out the fuel system end to end. From the line in to the tank thru the filter and so on remove the nozzle clean the screen and nozzle put it all back together. with the top section removed try to start the heater. You should have a fine mist of fuel and spark if it lights shut it down and clean the photo electric eye with a soft cloth and windex. make sure the igniter is clean and close to the fuel mist for ignition, put the top on and turn on your heater.
Dec 14, 2010 | Reddy Heater RH125T Kerosene Forced Air...
Ignition starter fail
Read these troubleshooting tips. You must determine whether the failure is a fuel delivery problem or an electronics problem.
Reddy Heater troubleshooting tips
Oct 19, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Jan 15, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater 110K btu motor won't start.
Bearing have gone bad in the electric motor. You will have to replace the electric motor. They are expensive but still cheaper than buying a whole new heater.
Jan 05, 2010 | Reddy HEATER RH125T 125,000-BTU...
RH125T won't fire
If you blew compressed air into the combustion chamber from the nozzle end of the heater there is a good chance that you broke the ignitor. Check it.
Dec 22, 2008 | Reddy HEATER RH125T 125,000-BTU...
Heating & Cooling Logo
219 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
