Question about Garden
Chainsaw won't stay running
My chainsaw won't stay running,it starts fine but dies after 20 or 30 sec..It has something to do with the primer button.I installed a new button and fuel lines,because the old ones were completly dry rotted and broke when touched. I think,I didn't get them back in the order they were hooked up before.Does anyone have a diagram,as to how they should be hooked up?
    Sergeant:
  • 359 Answers
Try fuel first drain fuel out replace . add small amount of carb cleaner , i like sea foam myself , available @ advance auto or like store then retry might have to restart several time to get into system . if no good then possible diaphragm in carb . but worth a shot before tear down
Posted on Dec 29, 2008
Chainsaw wont stay running Runs 30sec to about 1 1/2 min seems to be starved for fuel
Initial carb setting is 1 full turn out on both low and high side and retry. If no difference, then turn the low side out and additional 1/4 to 1/2 turn CCW. If that makes no difference, then it's time for a carburetor rebuild.
Feb 24, 2015 | Garden
Will not stay running
Not adjusted properly.
Dec 29, 2013 | Homelite Garden
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
Get a carb. rebuild kit.
Nov 29, 2012 | Husqvarna Garden
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
181 se chainsaw. runs for 30 sec then dies. new fuel new carb kit, completely cleaned, new plug
Check the fuel line going into the tank for holes or tears. When you get it to run for the 30 sec. it is running off the prime from the bulb. Once it is running it should be sucking gas through the fuel line to keep it running. A hole or tear in the fuel line will cause it to **** air and die out.
Jun 24, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Cratsman 40cc chainsaw will not run. i get it started and pull the throttle open and it wants to die, sounds like it starves for fuel. put new line from tank to carb, blew out carb, dont no settings for...
A quick test to see if it's running too lean (starved for fuel) is to gently push the primer bulb. If the motor spins up (revs), it's likely a clogged high speed jet. If it stalls immediately, then it's running too rich and you need to cut back on the high jet.
See http://www.repairfaq.org/samnew/lmfaq/lmadjc.htm for some quick and dirty (but good) instructions on adjusting the jets to fine-tune your engine.
As for the primer tube, if the bulb pulls fuel and fills up when pumped 3-8 times, then things are fine. If the bulb never gets fuel, then you may have identified a potential cause (missing tube).
Jun 01, 2010 | Garden
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,266 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
