RCA 32F531T 32" TV Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My daughter locked the TV, while trying to set up the DVD player and now the TV won't turn on, how do I fix that? She said it said, FAP locked ON. We don't have the remote for this TV so is there anyway that we can fix this soon?
Anonymous
Level 2:
Champion:
  • Expert 240 Answers
  • Posted on Jan 12, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
240
Questions
0
Helped
64927
Points
488
Press and hold TV ON on the remote and press the menue button on the tv set simultaneously for 5 seconds.
perental controls will then unlock.
regards,
daniel.
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
1helpful
Dvp sr520p disc tray locked
follow this steps and fix it. God bless you
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
test this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
My daughter has locked my jvc DVD digital theatre system and when I go to eject the DVD tells me it's locked how do I unlock it
You haven't given the exact model number ot your JVC DVD player here. Just download the user manual to your JVC model set, from net. It will have details about how to unlock the child lock to your set.
My daughter spilled water on Sony portable DVD player, now it won't turn on
No! when water enters it will rapidly corrode the ic pins and other critical parts, best to replace the player.
1helpful
2 dvds in built-in player
I have come across this a few times, one in fact last week!! The back needs to be removed from the back and the dvd section removed, Dont be afraid this is quite easy to do. lie the tv down face first and remove the stand and all screws, then remove the DVD section, should be 5 x screws and some leads that just clip off.
Then you will need a small screwdriver or a knife to prize the second dvd out, this may scratch your dvd but its better than your dvd player being broke!
Once out place the dvd player back in the set then re-screw it plug the leads back in and turn the set on and try to eject the first dvd, this should now be ok.
Once done, turn the tv off and replace the back on.
Just take your time and Obviously make sure the tv is not plugged in when removing the DVD.
Hope this helps
2answers
NO DISC
I bought a Dora DVD player for my daughter in March 2007. On November 2007 I inserted a disc into the player. It spun and stated there was no disc on the tv in the upper left hand corner. I tried 2 other DVDs and the same thing happened. I unplugged everything temporarily and plugged it back in and no improvements???
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
