Question about GE 29385GE1 Speakerphone
Beep During Conversation (New Question)
I'm posing this question again because there was no solution offered for my prior post. I have a GE Speakerphone, and every so often, while I'm in conversation, there will be a single beep. This does not happen in all conversations -- I'd say it occurs about once every ten times or so. My provider is Verizon. I've called Verizon several times about this, but it claims it has tested my line and there is no problem. The batteries of the phone are relatively new. Does anyone know what might be causing this?
  • 10,865 Answers
That beep means that you have another call coming in. If you want to take the other call you can tell your first caller to hold then push the hang up button one time and say hello. Now you will be speaking to caller number two. To return to caller one just push the hang up button a second time.
Posted on Apr 04, 2009
I need the answers
Sadly, I don't know the questions! Unless you post follow up questions through the links offered in the original question's answer, the new question appears entirely disconnected from the earlier one posed. It is also best practice to offer the device, brand, model number with a query. Otherwise, the search for an answer becomes unmanageable.
Nov 01, 2017 | Lands Phones
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
No startup, just a continous 2second beep
This means that something has gone bad...
The RAM failing in most machines is a consistent BEEP BEEP BEEP, but shorter than two seconds. This could be RAM, could be something else. I recommend having it physically checked out. Office Depot is offering free checkups for back to school, if you bring it in they will tell you what is wrong for free, then you can post again and get instructions as to where to buy the proper part and/or how to install it.
Hope this helps!!
Jim
Aug 06, 2009 | Acer Aspire™ T180 PC Desktop
Kepad beeping while using MagicJack
I have the same problem with the key pad beep during telephone
conversations and I hace a Uniden 5.8ghz phone.
So its not just panasonic 5.8 ghz phones that do the beeping.
Jul 11, 2009 | Panasonic Lands Phones
Is there any way to avoid the beep sound during conversation recording using Sony Ericsson K750i
That's a pretty standard beep used when recording calls; it's there so the person who you're recording knows that the call is being monitored. Cellular phone manufacturers don't offer a setting to change that beep due to legal concerns.
Jun 27, 2009 | Sony Ericsson K750i Cellular Phone
New GE Model 28821 Answering System HANGS UP after greeting announcement! HELP?! ;P
JUNK IT AND GET A PANASONIC.. THATS WHAT I DID. THIS GE PHONE IS THE WORST.
Jul 24, 2008 | Uniden Cordless Phone
Nokia N72
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
May 16, 2008 | Nokia N72 Cellular Phone
i want how frequently it occurs if it occurs always or sometimes like 1 in 10 times like that and which country you are who's ur provider
Apr 24, 2007 | GE 29385GE1 Speakerphone
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
GE 29385GE1 Speakerphone Logo
179 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
