Question about Frigidaire FGQ332ES Gas Dryer
Dryer won't start
When I turn the knob nothing happens. Dryer is only 4 years old.
  • stevez061 Feb 23, 2009
    I have a Frigidaire LGQ642DSO model gas dryer. It's only four years old. When I turn the start knob nothing happens except for a "faint" buzzing sound. I opened the dryer door and physically held the door button in and it appears to be working. Please help.
  • 700 Answers
Sounds like the door switch is malfunctioning on the dryer.
Posted on Jan 02, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Kenmore 63022 electric dryer, about 7 years old, h...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
Won`t start all the time when i turn the knob and push start it wants too but won`t
A dryer may not start for many reasons...
heatman101
Apr 11, 2010 | Crosley CDE6000 Electric Dryer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Frigidaire FGQ332ES Gas Dryer Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
