Question about Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera 3900 dn is printing slow
Is there a way of speeding the printer up?
    Genius:
  • 2,120 Answers
Turn off RAMDISK.
Posted on Dec 28, 2008
Light print come out in kyocera 2100 dn printer
Ensure that it is not on eco mode.
Are you using genuine or generic toner?
Jul 29, 2015 | Kyocera Office Equipment & Supplies
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
I have an HP LaserJet 3600 dn printer and I'm experiencing a problem with slow printing. I thought it was just when I tried to print PDF documents, so I tried to print a regular MS Word document, and...
When you print the config page, does it print slow?
If it prints at a reasonable speed, it's not the printer.
Are you using the USB port, the network port or a jet direct card?
One of those could be bad.
Jan 11, 2011 | HP Office Equipment & Supplies
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Kyocera printing very slow
Has it always been slow, or is that a recent development? At its fastest, the FS-2000 only prints 31 pages per minute, and that's for regular single-sided 8.5" x 11" with no special requirements. Anything else will (thick paper, longer paper, duplexing, etc.) will slow the print speed down.
One thing you can try to speed up the print speed is to change your spool options in the print driver. Go into the print driver (Control Panel > Printers & Faxes, right click on the FS-2000 and select Properties) and find where the spool options are located. Try selecting different spool options (such as waiting to send the job until all the pages have spooled, or sending it page by page) to see if any of them affect printing speed.
There are other options in the print driver's properties which could affect printing speed as well. Look around the different tabs and try changing some of the options to see if they make any difference.
You can also go to Kyocera.com and download and install the newest version of the print driver, which might speed up processing as well.
Hope that helps!
Mar 18, 2010 | Kyocera FS-2000D Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Slow printine
What memory dimms have been fitted.
Print status page see top right. May need more memory and a hard drive.
cheers
May 02, 2008 | Kyocera FS-C5030N Led Printer
Prints strange characters
You will need to do a fimware upgrade on the machine.
Feb 12, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900 DTN MONO LASER PRINTER Logo
562 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
